All Metal body filler
Old Apr 25, 2012 | 09:51 AM
Fliptard's Avatar
Default All Metal body filler
So I have read some stuff and didn't see anything on here. But I shaved my eg bay, welded all holes, and am using All Metal filler to cover up the welds.
I finished a couple spots, sanded it down with 220 then 400 to smooth it off and sprayed some black primer over it just to see what it looked like. It is smooth, however I can see the spots I filled. Could this be because I am just using cheap primer? Or do I need to use something else over the All Metal to finish it off?
I do plan to use much better paint when it's all said and done.
Thanks for the input.!
Old Apr 25, 2012 | 09:59 AM
joeshmo's Avatar
Default Re: All Metal body filler
You can use glaze to fill in imperfections. Use a quality, 2k urethane surfacer though. That'll surely fill the imperfections.
Any spots you see now will be worse when the gloss goes on.
Old Apr 25, 2012 | 10:02 AM
Fliptard's Avatar
It's not just the imperfections I see, it's the hole area that has the All Metal. Even with that, will the glaze still cover it?
Old Apr 25, 2012 | 10:10 AM
joeshmo's Avatar
Do you see the EDGES of your filler? If so, you need to do some more sanding and feather it out.
Old Apr 25, 2012 | 10:37 AM
Fliptard's Avatar
No, you see the whole spot of filler.the whole thing sticks out. I block sanded the spots so they were super smooth and feathered.
Old Apr 25, 2012 | 10:51 AM
joeshmo's Avatar
If the whole thing sticks out, they aren't level with the surrounding areas. Block with a higher grit to make it flat.
Old Apr 25, 2012 | 10:52 AM
Fliptard's Avatar
I shall try and post my findings. Thanks!
Old Apr 26, 2012 | 12:02 PM
PinkCivic999's Avatar
Hate to say it but you need to use a sealer or a really good primer like epoxy primer. Cheap aerosol primer doesn't cut
Body Filler Guide how to paint car
Old Apr 26, 2012 | 12:05 PM
joeshmo's Avatar
Absolutely. Urethane surfacer can be put over filler directly in most cases but epoxy primers are great for sealing and bare metal.
Old Apr 26, 2012 | 02:36 PM
Fliptard's Avatar
Yea, I kinda figured, guess Ill have to get some and hopefully that'll work!
Old May 1, 2012 | 08:48 AM
Fliptard's Avatar
I sanded it more after i added a thin layer of filler and also tried some icing and no matter what i do you can still see the area i filled in. I used so really good primer as well. Wth am i doing wrong? After i block sand it. It feels like the filler is lower than the metal...
Old May 1, 2012 | 07:46 PM
joeshmo's Avatar
How are you sanding? Are you using a block? Are you cross sanding?
Old May 2, 2012 | 12:25 AM
gorillafart's Avatar
is the all metal product brand new or was it something sitting around on a shelf for X amount of years?
are you mixing the product with the right amount of hardener?
are you using the hardner that came with the product?
did u kneading the hardner b4 mixing with the filler?
sand/remove it all, and try again... and cover it with at 2k primer/sealer...
and to my knowledge, you can put any type of primer over body filler (primer, epoxy primer, primer surfacer, primer sealer).. the only difference is, choosing the primer that is right for the job or what you can afford.
joeshmo: he has already established many times that he has sanded and feather edged.... that is not the issue... the issue is the filler is staining through the topcoat...
Old May 7, 2012 | 08:03 PM
Fliptard's Avatar
Brand new filler, mixing it plenty with the hardner than came with it at the right amount. I have some spots that are perfect. Can I get some epoxy primer in a can? And where/ what kind can I get?
Old May 9, 2012 | 08:03 PM
baynedo's Avatar
I have been using all metal for a few months for body work. i dont know how you can sand it down i have used 220 and it takes for ever. the best way I have found is sand with 80 grit and finish sand with 180. this filler is so thick you will almost alway need a glaze and finish sand it with 320. Good luck all metal will kick your *** if you let it.
Old May 13, 2012 | 11:35 AM
xkrazyxjbrkerx75's Avatar
metal glaze.....scuff primer and apply a small amount of metal glaze
duh702dc2
Paint and Body
May 10, 2014 11:43 AM
dvs94Teg
Paint and Body
19
Nov 13, 2010 08:59 AM
ken9
Paint and Body
12
May 30, 2009 07:41 AM
LittleDevilBmx
Jul 21, 2005 10:19 PM
HAcEx01
Sep 14, 2003 04:20 PM
