EF Civic Hesitation under load after warm up.
Old Apr 25, 2012 | 09:21 AM
broke88rex's Avatar
Default EF Civic Hesitation under load after warm up.
Hey guys I just picked up an Ef 90 civic hatch with an mpfi swap done. The swap looks pretty good on the ECU side. But I have a few concerns. There is no injector resistor box on the swap, and the distributor doesnt have the round white plugs that my CRX si had. So I am guessing that its not the td 02u dizzy that should be used. When I start the car in the morning, and leave for work or school, it runs well, as it should,(burns oil too). but then when its warmed up, it hesitates under load from around 1500-4000 rpm. I have replaced the Fuel filter, set timing to tdc. replaced all fuses. replaced pcv valve, replaced plugs.
I have done research and I havent gotten any symptoms of some idiot not using the right dizzy or a resistor box on an mpfi swap.
If someone could point me in the right direction on things to check so i dont spend a fortune on a motor that I am going to replace in the near future.
Old Apr 26, 2012 | 06:30 AM
broke88rex's Avatar
Default Re: EF Civic Hesitation under load after warm up.
Any Ideas? No one has had this problem?
Old Nov 12, 2013 | 06:42 PM
digitalkreation's Avatar
I've got the same issue precisely in my 03 CR-V. Just bought it, and it's sporting a replacement engine. Ran fine on test drive, ran fine for quite some time after driving it day 1 (of my owning it) but after it's warm, it wants to hesitate around 2600-3000 RPM.
Thoughts? Ideas? I really don't want a lot of repairs after just purchasing this vehicle. For what it's worth, it passed safety, though I know a vehicle WITHOUT an engine itself can pass..
Old Nov 13, 2013 | 08:01 AM
Glowicki's Avatar
I had a similar issue with my crx Dx with an si swap. Turned out to be my plug wires. A set of ngk wires off Amazon is about $40.
Old Nov 13, 2013 | 09:16 PM
Glowicki's Avatar
I'll just leave this here...
http://www.youtube.com/watch?v=9K78XIhhjAQ"]Video Link:
Carnal1988
Jan 22, 2019 02:12 PM
skateboard_ej8
May 19, 2008 03:33 PM
isaygo
Jan 9, 2007 01:05 PM
94eg5squadMD
10
Sep 25, 2006 10:48 AM
hondasean_204
Jan 16, 2006 03:49 PM
