97 civic ex no start
Old Apr 24, 2012 | 07:18 PM
jesse610's Avatar
Default 97 civic ex no start
whats up everyone. i got a issue with this car thats been working on me. It just got a tune ( plugs, wires, cap, rotor, fuel filter) then it lost spark. Replaced the dist. and it fired. Now it doesnt start. Cranks fine, timing belt is ok, has spark, but it floods. Noid is super bright. Theres no cel. ECT reads normal, but the injectors are running like 34ms. Soooooo my question is has anyone had a ecu go bad or am i missing something that would cause it to go full rich?
Thanks
Old Apr 24, 2012 | 09:48 PM
bigginsUT's Avatar
Default Re: 97 civic ex no start
there's something that went out on me a few years ago on me - it's called the ignitor inside the distributor. a small piece that's pretty tight up behind the rotor inside of the distributor. ya, you gotta get that plastic covering off to get to it. held on by 1 small bolt.
mine would start and would flood too. but then again, I had no spark either. make sure you got good spark - if not, then it's somethin to research
Old Apr 25, 2012 | 08:48 AM
jesse610's Avatar
Yea I know I have spark. I have everything just too much fuel commanded.
Old Apr 25, 2012 | 09:02 AM
beecee18's Avatar
check all injectors for good bill of health,
make sure none are sticking, if this was the case you would have a hole wetter than the others
Old Apr 25, 2012 | 01:28 PM
jesse610's Avatar
I'm thinking its more of a control issue because the nous light is super bright. And the objectors are running at like 34ms when normally its like 15 ish
Old Jun 16, 2012 | 09:39 PM
texasbootboy's Avatar
i had the same problem the car would crank and i would only get a battery and oil light on only and no cel i ended up rigging it up there is a wire(i believe it was a black and yellow stripe or red stripe wire) at the ecu that i grounded that wire and the cel came on the car then started. i also noticed the fuel pump also kicked in when i grounded that wire. if i could i would like to fix it the right way if any one know what it can be i can ck that wire tomarrow and let you know it can be worth a shot.
Old Jun 18, 2012 | 06:51 PM
it is a black and red strip pin 18 when i cut and grounded this wire (to the ecm ) my check engine light went off. the only thing is i wish i knew what this wire was for
sr20paisa
18
Jun 10, 2016 05:35 PM
Travis Theroff
Jul 23, 2013 10:32 AM
MATiC
Jan 27, 2007 08:28 AM
Circuit8
Nov 26, 2001 03:14 PM
