99 honda accord 4cynl
Old Apr 24, 2012 | 11:12 AM
nova1370's Avatar
Default 99 honda accord 4cynl
I need help really bad car died while driving and would not start again first time ever happened the car cranks fine but will not turn over changed main relay still will not turn over please help only means of transportation!!!!!!
Old Apr 24, 2012 | 11:15 AM
Fichtenelch's Avatar
Default Re: 99 honda accord 4cynl
Does the fuel pump run when you switch the ignition on? If it runs, check the distributor, battery, spark plugs and cables. Does it spark when you take one of the spark plugs out and motor the engine?
Old Apr 24, 2012 | 11:31 AM
nova1370's Avatar
sry fuel pump good distributor,battery,spark plugs and cables are good was having some problems before with it bogging at 4,000 rpm but car was running fine besides that
Old Apr 24, 2012 | 11:58 AM
If you take a spark plug out, does it spark when motoring the engine? does it start on start-spray or brake cleaner sprayed in the intake manifold?
Old Apr 24, 2012 | 01:52 PM
nova1370's Avatar
yes it sparks but spark plugs are dry should they be wet if the car cranking but not turning over
Old Apr 24, 2012 | 01:56 PM
nova1370's Avatar
if its injectors is there any way i can drive car home about 15-20 miles
Old Apr 25, 2012 | 11:55 AM
VeeSykkz's Avatar
turn it over a few times and THEN pull out a plug or 2. See if you smell fuel in the cylinder.
Tyreezy
Jul 3, 2016 01:22 PM
ScareCrower
Jul 8, 2015 05:49 AM
black90.prelude
Feb 10, 2014 04:22 PM
715_guy
May 13, 2008 08:27 PM
