Huge oil leak from head, what happened? With vid
Old Apr 23, 2012 | 10:31 PM
MoreCowbell's Avatar
Default Huge oil leak from head, what happened? With vid
Rebuild recently but shish I messed up somewhere along the line.. Wtf happened??
I did the initial startup for 10 seconds or so and now have a HUGE puddle of oil on the floor.
http://i259.photobucket.com/albums/h...1/cb8beaff.mp4
Video link above
Old Apr 23, 2012 | 10:43 PM
Default Re: Huge oil leak from head, what happened? With vid
Son of a.. Did I have the head gasket flipped upside down?
I could have sworn I lined it up right when installing
http://www.team-integra.net/forum/11...esolution.html
Old Apr 23, 2012 | 10:47 PM
ProjectEvilEj2's Avatar
Your video dnt wrk on my iPhone but it should a easy fix, trace the oil leak. I'm almost sure it's from oil filter or maybe you pinched down you oil an gasket when tourqin down the oil pan causing the leak. Those are the only area that channels oil where people failed to check.
The block say it's a Gsr so I'm guessing it can't be a lsvtec oil line rite? So check those area. Also did u lube the seal on the oil filter when u put it on?
Old Apr 23, 2012 | 10:48 PM
Is it coming from between the head and block?
Old Apr 23, 2012 | 10:54 PM
00_EKHatch's Avatar
Gotta be the head gasket upside down man. Seen it before. Sad to say but, better tear it down again.
Old Apr 23, 2012 | 10:59 PM
I don't see any tab there for the headgasket.. Installed incorrectly ?
Old Apr 23, 2012 | 11:01 PM
If it coming between the head and block then of crose you messed up on the HG bro. Only reason why oil well leak from between there. Unless somthing was stuck between there too.
Old Apr 23, 2012 | 11:52 PM
guess_who's Avatar
Yeah man. That appears to be upside down.
Old Apr 24, 2012 | 12:54 AM
Runnerdown's Avatar
Yeah it's flipped the wrong way. The oil pours out from the block on the vtec oil supply feed.
Old Apr 24, 2012 | 01:24 AM
Dc4LsTeG's Avatar
EK9
Yea you should be able to see the gasket there. Its installed wrong
MumBleZ_94gsR
May 30, 2009 03:26 PM
xTimmyx
Oct 14, 2007 10:43 AM
jason190
Mar 31, 2005 08:12 AM
G3gsr
May 20, 2003 06:17 PM
