SF Bay Area - Parting out Turbo DA Integra
Old Apr 23, 2012 | 06:33 PM
qwkteg125's Avatar
Default SF Bay Area - Parting out Turbo DA Integra
Car is now being fully parted out. Let me know what parts you need if not listed and i'll get you a price. I will be updating this thread with pictures as I pull parts off the car. Located in San Francisco.
Shell – $750
Painted Lexus Platinum Silver - Clean title; no accidents or rust -
Custom external mount Endyn Bosch fuel pump
Earls -6 feed line from pump to rail
Lightspeed stainless brake lines
Axxis Metalmaster pads
Prothane complete urethane bushing set
OEM 92-93 front & rear bumpers
JDM front bumper support
14" LS Snowflakes with good tires
Clifford IQ-800 alarm with custom locks
Engine -
AEM Cam Gears (pair) - $SOLD
Fluidyne 92-95 Civic radiator with Permacool slim fan - $SOLD
ARP B18C/LS-VTEC 208-4303 head studs, torqued down only once - $SOLD
Type-R throttle body - $SOLD
Spoon Radiator Cap - $SOLD
Type-R valve cover uncut, includes valve cover grommets - $SOLD
GSR power steering bracket, cut in half for clearance on my Full-Race manifold; works great - $SOLD
Short Block - $650
B18A LS block 118k miles, approx. 38k on rebuild. My car hasn't been driven for the last 4 years besides the occasional start for a few minutes to keep the fluids circulating or to move the car out of the garage, so I am selling everything for the price of the rods themselves. Last compression test was 175-180 across the board.
JE SRP 9.0:1 cr .010 over pistons
Crower steel billet pro rods
Micropolished and balanced crank
Z10 engineering main block girdle
Prodrive billet oil pump gear
Nuformz block guard
Type R Oil Pump
Type R Water Pump
98 GSR Oil Pan
98 GSR oil pickup
98 GSR windage tray
98 GSR water pipe
98 GSR oil cooler
Mugen thermostat
2000 Type-R cylinder head (tapped for LS-VTEC but plug can be removed) - $375
Comes with VTEC solenoid, rockers, cam caps, Endyn Titanium retainers/dual valve springs, (B16A2 cams additional $25)
Type-R intake manifold - $175
Comes with IACV, intake air temp sensor, 2 extra vacuum ports
Greddy oil filter sandwich adapter - $35
B16A2 cams - $50 (or $25 with purchase of head)
Earls -6 line used for oil feed on my LS-VTEC setup - $20
Turbo –
Tial 44mm wastegate - $SOLD
Thermal R&D 3” stainless exhaust - $SOLD
3" Random Technologies cat with 3 bolt flanges - $SOLD
Earl's -10 oil stainless oil return - $SOLD
Custom 3” thick Spearco backdoor intercooler, 2.25"aluminum piping, silicon couplers, t-bolt clamps - $SOLD
HKS SQV Type C BOV - $SOLD
Precision 60-1 Hifi turbo (3" .60 ar cold side, 2.25" .48 ar hot, billet aluminum backplate) - $SOLD
90 degree 2" to 2.25" silicone hose transition - $SOLD
Full Race T3 ProStreet manifold flanged for 44mm waste gate - $750
Full Race 3” stainless downpipe with flex - $150
3" test pipe with 3 bolt flanges - $75
NEW 1.75" stainless J-bend to fabricate dump tube - $25
TurboXS manual boost controller - $40
Earls -10 low profile 45 degree swivel seal female hose end - $10
Earls -10 90 degree auto-fit female hose end - $10
Fluids -
2L Ate Type 200 Brake Fluid - $20
5Q Royal Purple 20W-50 Full Synthetic - $30
4Q Castrol GTX 20W-50 - $15
7Q Pennzoil 20W-50 - $25
Fram Oil Filter - free to 1st person to buy some oil
Fueling –
Custom Type-R fuel rail with -6 feed port, B & M FPR & Jegs Liquid filled Fuel Pressure Gauge - $SOLD
Earls -6 line with inline fuel filter - $SOLD
MSD Digital 6 ignition - $200
MSD RPM activated switch with 5000rpm pill - $50
Speedpro bank to bank engine management with Honda wire harness, 3 bar map, WBO2 sensor - $500
RC Engineering Bosch P&H PB2X-720 720cc injectors - $200
MSD Blaster SS coil - $20
Suspension –
Tokico Illumina shocks with ground control coilovers - $400 plus your old suspension
Full Race adjustable traction bars - $SOLD
NEW Ground Control Springs (pair) 8" 380 lb - $SOLD
Dunlop SP Sport FM901 205/40/16 tires 95% tread - $SOLD
OEM axles (pair) - $70
PowerStop cross drilled rotors - $100 for all 4
email qwkteg125 at yahoo dot com for parts/picture requests
qwkteg125's Avatar
Default Re: SF Bay Area - Parting out Turbo DA Integra
Interior –
MB Quart 130.03 kx 5.5" speakers with crossovers and tweeters - $75
MB Quart 218.03 cx 6.5" speakers with crossovers and tweeters - $100
Momo Race steering wheel - $SOLD
Momo Hub - $SOLD
NRG quick release hub with lock - $SOLD
Greddy 52mm boost gauge - $SOLD
Greddy 52mm oil pressure gauge - $SOLD
Greddy Turbo timer - $SOLD
A-pillar pod 52mm single - $SOLD
Greddy 52mm adjustable gauge holder - $SOLD
Clean Interior no rips or tears anywhere - inquire
90-91 Cluster with 90-91 XSI Tach (9.5k tach, 8k redline) - $150
90 LS cluster NR white overlays - $25
Alpine 9833 MP3 CD head unit great condition- $150
Custom trunk mounted sealed sub box with 1 Kicker Impulse 652xi amp (65w x 2) and 1 Kicker Impulse 354xi amp (35w x 4); 2 Kicker 8” Solo Baric S8D subs - $400
Razo Carbon Fiber Pedals - $30
Floormats - $50
qwkteg125's Avatar
Exterior -
JDM one piece headlights - $SOLD
H4H HID kit with Philips ballasts & bulbs & wiring harness - $SOLD
Zenki extended open end black aluminum lugs and valve stems (faded to bronze) - $SOLD
JDM 92-93 tail lights - $ 125
92-93 oem bumper turn signal lights (painted amber) - $40/pair
OEM spoiler pained Lexus Platinum Silver - $25
qwkteg125's Avatar
reserved 3
Old Apr 23, 2012 | 06:34 PM
qwkteg125's Avatar
reserved 4
qwkteg125's Avatar
reserved 5
Old Apr 26, 2012 | 08:54 AM
qwkteg125's Avatar
Bump
Old May 3, 2012 | 05:23 PM
qwkteg125's Avatar
updated pics
Old May 6, 2012 | 03:34 PM
g0tgot's Avatar
bump PMd
Old May 12, 2012 | 09:56 PM
qwkteg125's Avatar
new parts/pictures added
Old May 12, 2012 | 11:12 PM
Nutzurchin's Avatar
Icon5 Re: SF Bay Area - Parting out Turbo DA Integra
Check you pm
Old May 13, 2012 | 10:57 AM
eg714's Avatar
Good price. How many hp is that fmic good for?
Old May 14, 2012 | 10:19 AM
qwkteg125's Avatar
I made 360hp on it. The person who owned it before me made 400+. I believe the core size is 20 x 8 x 3
Old May 15, 2012 | 11:19 AM
qwkteg125's Avatar
bump
Old May 16, 2012 | 12:20 AM
ND831's Avatar
Pmd you, good parts.
Old May 16, 2012 | 09:13 AM
qwkteg125's Avatar
replied
Old May 17, 2012 | 09:57 AM
qwkteg125's Avatar
Old May 18, 2012 | 09:04 AM
qwkteg125's Avatar
Old May 19, 2012 | 11:06 AM
qwkteg125's Avatar
Old May 20, 2012 | 02:28 AM
qwkteg125's Avatar
new parts/pics added
Old May 21, 2012 | 09:47 AM
qwkteg125's Avatar
Old May 23, 2012 | 01:49 PM
qwkteg125's Avatar
Old May 25, 2012 | 10:39 AM
qwkteg125's Avatar
Old May 29, 2012 | 02:18 PM
qwkteg125's Avatar
Old Jun 6, 2012 | 03:58 PM
Colin's Avatar
sorry to see this ol' gal parted out Good stuff in here though.
