Temp guage fluctuates between 1/4 to 1/3
Old Apr 23, 2012 | 03:38 PM
ax77's Avatar
10 Year Member
Default Temp guage fluctuates between 1/4 to 1/3
So for about 2 years I drove around with a thermostat that was stuck closed and didn't realize it until recently. The engine never overheated. Temp gauge was always 1/3 of the way but my fan would constantly run. I thought it was a bad coolant switch or fan relay but it turned out to be the thermostat. So i bought an OEM thermostat and now i get fluctuating temps. With the car sitting at idle everything seems fine. Temp gauge goes to 1/3, fan turns on and off but with the car moving my gauge goes to 1/4. Is that normal? Shouldn't it constantly be at 1/3? I purged the air out of the coolant. any advice?
Old Apr 23, 2012 | 10:27 PM
nicknack25's Avatar
Default Re: Temp guage fluctuates between 1/4 to 1/3
Did you bleed your coolant correctly? And did you test your OEM termostat before putting it in? It's always a good idea to test it before you put it in. Sounds like the thermostat is somehow stuck open.
Old Apr 24, 2012 | 08:48 AM
ax77's Avatar
10 Year Member
I actually did test the thermostat before installing it. I purged it according to the manual but I can try again.
Old Apr 24, 2012 | 10:49 AM
nicknack25's Avatar
Are you 100 percent sure you installed it in correctly? Even with the pin on the upper side?
Old Apr 24, 2012 | 11:56 AM
ax77's Avatar
10 Year Member
yup I'm sure. I wonder if it has to do with a new bumper I recently put on. Maybe it has more venting. The temp is fine while the car is not moving. Also I don't have AC if that makes a difference.
Old Apr 24, 2012 | 03:02 PM
nicknack25's Avatar
I highly doubt this has anything to do with your new bumper.. If the temp is fine while the car isn't moving, then the thermostat is stuck open. i recently had this problem but i was using a non oem thermostat and i switched to oem and it was good. Not sure why or how, but you have a defective thermostat.
ddb332
Dec 22, 2016 10:46 PM
ALDJ253
Mar 9, 2014 07:23 AM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
S@nt0s
12
Feb 25, 2004 05:16 PM
