steering rack
ok so i have a "non power steering rack" that my friend did for me.
he took the power steering out and took the rack and cleaned it and greased it out.
but now after installed, i feel alot of play on the steering wheel and ontop of that it makes "cracking noises"
did something go wrong or what?
Did your friend put in the p/s delete kit? Or did he just unhook the hoses and called it good? I've never done this before but my understanding is that you should have the feed and return lines from the rack connected to each other. There was a guy that was selling a kit but it's been a while now. Don't know if he's still in the biz.
From what u mentioned, the plays could be your inner and outer tie rods instead of the rack & pinion itself. The so-called "P/S delete" is just simply put a U-shaped hose from the outlet to the inlet to recirculate the fluid inside the rack. I did it on my DC2 once, but I kept a certain level of P/S fluid and didn't coat any grease at all. Check the outer tie rods by visually checking the dust boot if there are cracks on them and moving them back and forth. Good tie rods should be pretty solid that has from little to No play! Ripped inner tie rods bellow boots would let the grease dry out and result in creaking noise when steering. Worst case scenario, go to wreck yard and buy a manual rack off from any 92-00 civics or pepboys has some remanufactured manual rack for sale for a good price. I bought mine for 130 bucks. Hope this is helpful to you.
Ok thanks I'll get back to you guys after I do research and see if my tie rods are just the problem with the play and cracking noises. But if it is just the tie rods
Could I just change that instead of changing the rack?
Replacing outer tie rods are pretty straightforward, but you need special tool for inner tie rods.
