Worth changing blocks?
Old Apr 23, 2012 | 02:28 PM
JustDoingMe's Avatar
Default Worth changing blocks?
Sup ht, just wondering if it would be worth it to change the block on my b16a2 for a b18c block. I found a b18c block for $300 with everything except the rings and bearings, seems like a good price to me but would the end result be much better then my b16 now? I'm planning on turboing it in the future.
Old Apr 23, 2012 | 02:44 PM
D.A9 GUY's Avatar
Default Re: Worth changing blocks?
a HOLE ex the rings and all for $300?the top end goes for that much and yes, due to the higher displacement of the engine it would come out 100% better than that b16...it just feels more meatier if you know what i mean .for $300 you just cant beat that price man!In my opinion a b16 is nice but a b18c is were it at there's just more low end power in that engine.. in the end its your choice!
Old Apr 23, 2012 | 10:41 PM
cagedGSR's Avatar
No replacement for displacement.. I would pick it up.
Old Apr 23, 2012 | 10:58 PM
racebum's Avatar
x3
b18c is all around a better platform to build off of
Old Apr 23, 2012 | 11:05 PM
Dc4LsTeG's Avatar
EK9
X4 but it will be more then 300 cuz your going to have to rebuild it ex rings,bearings,hone, etc
Old Apr 24, 2012 | 05:56 PM
I'll try and pick it up but something seems off. He told me it only has 90k miles, that's pretty low.
Edit: Would a b18c block with a b16 head make the same power as a gsr or more?
Old Apr 24, 2012 | 10:23 PM
racebum's Avatar
can, depends on the pistons. the nippon usdm itr piston would be a good choice for an NA build. they are slightly larger than the usdm dome. be real easy to hit 11:1 compression if you shave the head slightly to true it up
b18c block and pr3x head is the casting of an itr
Old Apr 25, 2012 | 07:37 PM
Hidenplanvew's Avatar
I would say 200 to 250 for a C1 block.. Your prob going to need to et the block decked, hone, and rings and bearings might also need a micro polish for the crank.
Old Apr 26, 2012 | 07:51 PM
Just wondering...how much would that all cost? lol
xkjnboix
Mar 14, 2016 06:16 AM
zero2sxity
Nov 6, 2003 06:01 PM
B pwr
Jun 16, 2003 07:01 PM
blmracing
Dec 16, 2002 01:37 PM
