Neutral Safety Switch w/ auto to trans swap?
I have a 94 prelude that has a h22a1 swapped into it, it used to be a auto, but was converted to a 5spd. The car starts fine and all, but I need a neutral safety switch that'll work, so I can't start the car while it's in gear. I need that so I can pass inspection (car came from north carolina and I'm in Virginia... any help? Ive already searched btw.
Should I just go get the neutral safety switch for my model, but 5spd?
#13 - 35710-SE3-A01 - SWITCH ASSY., CLUTCH (INHIBITER)
That is the correct part for a 5 speed, majestic Honda lists $34 new. You'll also need #20, pedal stopper too. Not sure how you'd wire it into an auto car though, never done a auto to 5 speed swap, from what I see most people bypass it but in your case you can't.
http://www.hondaautomotiveparts.com/...3ss001_b23.png
I might also trying to get it passed without.
You would need too look at a schematic and find the starter solenoid wire coming off the ignition switch. cut it and add the clutch switch into the circuit. pretty simple really.
miked198729
Oct 27, 2014 06:14 PM
crapanese
Sep 14, 2008 01:33 PM
