where do you locate the diagnostic port on a 1989 honda civic SI
Old Apr 23, 2012 | 08:49 AM
ElCivic89's Avatar
Default where do you locate the diagnostic port on a 1989 honda civic SI
where do you locate the diagnostic port on a 1989 honda civic SI. So i can Scan a Code Check engine light is on.
Old Apr 23, 2012 | 08:51 AM
Dc4LsTeG's Avatar
EK9
Default Re: where do you locate the diagnostic port on a 1989 honda civic SI
Just jump the service connector and check, search how. Or does your ecu have the red led on it?stock ecu?
Old Apr 23, 2012 | 09:05 AM
BLU CIVIC's Avatar
Track Advocate
your car's obd-0 so you can't scan...believe that's only on vehicles '95 and up.
will have to do as ^ indicated if your ecu doesn't show the flashing light
http://www.crxsi.com/reference/ecu_codes.htm
The ECU is located at the front of the passenger footwell, under the carpet. There is a single flashing light in the center of the ECU that flashes the codes. Simply count the flashes in each sequence to determine the code.
Code 0 _____ Faulty ECU
Code 1 _____ Oxygen content
Code 2 _____ Does not appear to exist
Code 3 _____ MAP sensor
Code 4 _____ Crank angle sensor
Code 5 _____ MAP sensor again
Code 6 _____ Coolant temperature
Code 7 _____ Throttle angle
Code 8 _____ Top dead center sensor
Code 9 _____ No. 1 cylinder position (only on 1.6L)
Code 10 ____ Intake air temperature
Code 11 ____ Does not appear to exist
Code 12 ____ Exhaust gas recirculation system
Code 13 ____ Atmosphric Pressure
Code 14 ____ Electronic air control (EACV)
Code 15 ____ Ignition output signal
Code 16 ____ Fuel injector
Code 17 ____ Vehicle speed sensor
Code 18 ____ Does not appear to exist
Code 19 ____ Lock up control solenoid (auto trans only)
Code 20 ____ Electric load
Old Apr 23, 2012 | 10:51 AM
ElCivic89's Avatar
all stock 1989 SI i will check the codes?
Old Apr 23, 2012 | 10:54 AM
4drEF's Avatar
Keyboard Humorist
I'm not sure. You tell me.
Will you?
Old Apr 23, 2012 | 12:15 PM
JDpower's Avatar
You don't even have to jump the connector just pull up the carpet turn the ignition to on, look at the red LED light and start counting the number of blinks.
Old Apr 23, 2012 | 01:00 PM
ElCivic89's Avatar
17 Blinks.
Old Apr 23, 2012 | 01:03 PM
Jockone's Avatar
Check codes list supplied by Blu Civic above.
Code 17 = Vehicle speed sensor.
Old Apr 23, 2012 | 01:10 PM
4drEF's Avatar
Keyboard Humorist
Does your speedometer work?
Old Apr 23, 2012 | 01:25 PM
ElCivic89's Avatar
yes it works i just replaced the speedo cable and now this check engine light is on with Code 17 ____ Vehicle speed sensor. What should i do next?
Old Apr 23, 2012 | 01:37 PM
4drEF's Avatar
Keyboard Humorist
Did it just start this problem when you replaced the cable?
If so, remove your cluster again and check the speed pulser.
It is the ring around where the cable plugs into the back of the cluster.
efcivic2dr
Apr 1, 2008 09:20 PM
BLUE EH3
Jan 12, 2007 01:00 PM
Chris_Bye
Jul 10, 2004 12:10 PM
stockintegra
Mar 27, 2004 02:13 PM
ang
Nov 27, 2001 09:38 PM
