97 civic was misfiring and now stopped running
Old Apr 22, 2012 | 06:35 PM
Laura Ilkenhans's Avatar
Default 97 civic was misfiring and now stopped running
have a 97 civic misfiring idles fine today stopped running any help please
Old Apr 22, 2012 | 07:20 PM
Former User's Avatar
Default Re: 97 civic is misfiring
More information would help.
Stock Civic? Mods? Trim? CEL codes? Spark? Fuel? What have you done already?
Old Apr 22, 2012 | 07:31 PM
Dc4LsTeG's Avatar
EK9
Default Re: 97 civic was misfiring and now stopped running
X2 on cels?
Old Apr 24, 2012 | 07:16 PM
no cels i have fuel to the fuel rail and spark to the plugs put on anew rotor and cap got a one second run now nothing again . pulled plugs have fuel on them. wonder if coil is not strong enough .will check timing next
Old Apr 25, 2012 | 04:44 AM
motegicivic's Avatar
Could be a bad coil.
Old Apr 25, 2012 | 06:00 PM
the timimng cheked out ok. the resistance on the coil ok. power to the coil and icm but after one second run no spark., will put anew icm next iguess unless thier is somethying else to do
Old Apr 25, 2012 | 06:08 PM
Dc4LsTeG's Avatar
EK9
What color spark are you getting?
Old Apr 26, 2012 | 03:36 AM
not getting spark any more. but it was blue/white
Old Apr 26, 2012 | 03:28 PM
well it turned out to be the coil it runs but misses sputters and pops under load any suggestions
Old Apr 26, 2012 | 03:35 PM
Do a tune up.
Old Apr 27, 2012 | 06:56 AM
Did you replace the coil and it still runs bad?
Old Apr 28, 2012 | 04:22 PM
yes ihave repleced the coil, icm,plugs, wires,cap and fuel pressure regulator and it still runs bad
Old Apr 28, 2012 | 05:34 PM
You did a lot of the basics and more so. Did you do the fuel filter?
How many miles?
Here is something to consider. Might be low compression or valves seals or worn engine.
If you have a rough running engine and you done all the basics no CEL's sometimes low compression will cause it to run rough, then it is time to swap or rebuild.
Another thing any signs of a bad head gasket, same thing you will get a slight leak in the gasket allows exhaust gases into the cooling system and will run intermittently rough esp when warm.
Old Apr 28, 2012 | 06:12 PM
apexi_rsx's Avatar
a clogged catalytic converter can cause this if extremely clogged.
Old Apr 28, 2012 | 06:32 PM
thanks for ideas. iforgotto mention it but i replaced fuel filter first thing. iam going to check the timing first if it is ok check the cat and do acompression test and look inti head gasket problems. oh it has178k on it.
Old Apr 30, 2012 | 01:48 PM
well after all that i had mixed the 2 and 3 plug wires it runs great now. tks again for the help
Old Apr 30, 2012 | 04:58 PM
Really, that is interesting.
Brandeno
May 31, 2015 08:55 AM
2boysboostin
Jul 28, 2008 05:31 PM
BadBeck
Dec 11, 2003 05:59 PM
SleeperCivicEX99
Sep 9, 2002 08:48 PM
DCtwoR
Aug 13, 2002 07:51 PM
