DIY S2k Cluster Into EG * HAS VIDEO*
DIY S2k Cluster into EG
CodyForTheNguyen
Materials
S2k Cluster AP1 ← THIS IS FOR AP1
Speedohealer V4
Coolant/Oil Gauge
Phillips Screwdriver
Shrink Wrap *Optional
Soldering Kit* Optional
Extra Wires* Optional
Hello everyone,
My name is Cody and this is the first time I am doing a DIY, I am going to try to make it was simple yet have enough to more than enough information so that anyone can understand it. I looked at a bunch of DIY and none of them fully explained how to do it. For those of you who think you can understand it quickly I will provide a link to my DIY Video (:! Ok so lets get your s2k cluster into your eg!!!!!
First thing you will need to do is take off the dash inside the car.
There is two Phillips screw up. Unscrew These
You will need to GENTLY pry out the hazard lights. This can be easily done with a flathead or your nails. Do not yank it out because it plugged in. Unplug the plug
Next place a flat head under the dash and slide out GENTLY. DO NOT PULL DASH ALL THE WAY OUT
Pull The Dash out just enough to where you can locate the Clock Plug then Unplug that
Now you can take out the dash, the cluster it self has 4 Phillips screws. Top Left, Top Right, Bottom Left, Bottom Right. Take those out. Now Gently Wiggle the cluster out of the car. Now you will have to unplug the cluster
I will provide links to charts and graphs I used.
http://www.d-series.org/forums/diy-f...-eh-bezel.html (He has a DIY but he never finished it I followed his color charts)
DO NOT FOLLOW A B OR WHATEVER!! JUST FOLLOW THE COLOR CODE!! IF YOU FOLLOW THE LETTER CODE FROM THESE TWO DOWN HERE IT WILL NOT WORK WITH THE ONE ONTOP AND YOU WILL BE CONFUSED AS HELL
http://www.marklamond.co.uk/products.../pinout-eg.htm
(EG Color Code)
http://www.marklamond.co.uk/products...inout-2000.htm
(s2000 Color Code)
I suggest wiring everything up before you decide to solder it.
I took the pigtails from the EG and snipped of a little bit and used that color and just twist it into the s2000 pigtails.
That’s how mine came out. Do not be alarmed because there maybe wires you do not use. There was a lot of power and ground wires so I just used tape to show which ones were ground and which ones were wires.
Testing it
I did not take a picture of the soldering/ heat shrink however that is located in my video.
I still have to show you guys an install of the speedohealer and the gauge.
The reason you have to get a gauge now is because Modifry is sold out or either doesn’t make it anymore ):
I will edit as soon as possible.
Please if anyone knows how to do the fuel/gas light please help me!@!@
I know its yellowblack/yellowwhite S2k/EG
Heres the Video I hope it helps
http://www.youtube.com/watch?v=BuSq5_qTcWg
CodyForTheNguyen
Materials
Speedohealer V4
Coolant/Oil Gauge
Hello everyone,
(EG Color Code)
(s2000 Color Code)
Testing it
