Filter or screen in p/s reservior on '91 Accord
Is there a filter or screen inside the p/s fluid reservior on my '91 Accord LX wagon? If so, can it be replaced or does the whole reservior need to be replaced to have a new clean filter or screen?
I just finished installing a steering rack, all new p/s hoses, and resealing my p/s pump. My fluid was pretty dirty. Nothing in the steering system had been serviced in it's 315k miles so far. We don't want a car payment so it looks like the old wagon is going to get a whole bunch of work.
I have clean the screen out without any problem for precaution. But even cleaning needed? If you don't have clog, then sucking out the old fluid and replace new is more than efficient. If it's clogged then remove the reservoir, use brake fluid to thorough clean it. Blow compressed air to dry and put in a little new fluid in there while the reservoir is still off to check for flow. Then reinstall the reservoir. What I did was draw old fluid from reservoir, put in new fluid, jack the front of the car up, then steering lock to lock 3X, then engine off, draw old fluid, in new fluid, etc... I did it 5 times and it's about 90% clean. Only use Honda's fluid. Remember, that the fluid is clear in the bottle, once expose to air, it will turn yellow. So if you see yellow does not mean it's old.
dk199160
Oct 23, 2015 11:54 AM
theLemur
Dec 27, 2014 01:01 PM
NightHawk92
15
Jul 16, 2014 08:41 PM
integracura
May 29, 2006 04:32 PM
Overmind22
Mar 28, 2004 09:47 AM
