Hitachi Dist. Swap 95 Accord EX F22B1
First off my specs are stock '95 Accord EX VTEC F22B1, OBD1.
I am looking to swap out my hitachi distributor; mainly for parts availability and also because I cannot replace the inner hard seal behind the shaft in the dizzy housing from where oil is leaking from. The NOK BH3888(E) inner seal does not fit Hitachi. I do not mind splicing wires to get the wiring to work. As pointed out by GhostAccord:
Some possible swaps I've read somewhere here are:
What is the latest TEC dizzy that has CKP, TDC & CYP sensors included that I can use.
OR
Is there any distributor I can use from a newer Gen that would work if I did some modding. Thanks.
There are two different types of dizzies used in the 5th gen 94-95 OBD1 Accord (F22)
The OBD1 94-95 DX & LX use the TD-59U (TEC external coil) and
The OBD1 94-95 EX uses the D4J92-04 (Hitachi internal coil)
Both of these OBD1 Dizzies have the CKP, TDC & CYP sensors inside the distributor. Anything after 95 is OBD2 and IIRC they only have the TDC sensor in them.
- TEC TD31
- TD-34 (U)
OR
Any suggestions or feedback guys? Any help would be much appreciated. I'm not familiar with TEC distributors. And tired of the oil leak. I can't really afford a whole new hitachi distributor now and I already bought a used one and its leaking from the internal seal again already. :
ZillaG
Apr 6, 2016 02:56 PM
