NEED INSIGHT!! 2nd GEAR started POPPING OUT.. B16Z6/HYDRO.. any suggests?
Old Apr 21, 2012 | 12:04 PM
ZenDog73's Avatar
Default NEED INSIGHT!! 2nd GEAR started POPPING OUT.. B16Z6/HYDRO.. any suggests?
need insight.. 2nd GEAR started POPPING OUT..d16Z6/HYDRO.. any suggests?
Old Apr 22, 2012 | 07:50 AM
Runnerdown's Avatar
Default Re: NEED INSIGHT!! 2nd GEAR started POPPING OUT.. B16Z6/HYDRO.. any suggests?
Never heard of that motor, but in any event the transmission needs to come out and get pulled apart most likely. D series trans can have the countershaft bearing walk out of the case and cause this. Or a pile of other possible issues that nobody can see from here.
Old Apr 22, 2012 | 08:35 AM
MR.johnson's Avatar
if its a D16z6, pound the ISB back down and stake it.
fcm's Avatar
fcm
Old Fart
Ditto the above, I would also check shift "linkage" make sure #13 and #14 are not bent.
Make sure #14, Extention Change Rod is functioning properly, make sure #s 10, 18, 19, and 26 are there and working as they are supposed to, the same goes for #s 15, 16, 17 and 30 at the other end, in fact make sure anything to do with the shifter is there and working properly and not worn out...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
If all the above is in good working order, you will, as mentioned, have to pull the transmission and open it up, I would check the shift forks and shafts, they can be worn out or bent...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal 94
m.glisson003
Transmission & Drivetrain
May 17, 2013 01:50 PM
CRXREFIC
34
Jul 26, 2010 02:07 AM
stevenDAtegra
Feb 4, 2010 12:43 PM
92civiceg9gsr
Feb 6, 2009 08:53 PM
Quickridez_3
May 4, 2008 08:08 PM
