Need help installing Turbo on H23 , 95 intergra , but troubles.
Old Apr 21, 2012 | 11:10 AM
Black_horse's Avatar
Default Need help installing Turbo on H23 , 95 intergra , but troubles.
Hi
I'm new here , I have serious issues with my integra.
I replaced my B20 engine to H23 for better performance , anyway , I'm planing on installing turbo , but right now , I have this unknown issues , when accelerate , vtec works , the car sometimes would hold back or just goes heavey when accelerating . That when car temp reach it's normal temp 1/4 , if it colder , it accelerate fast , is that normal ?
When turning AC on and get vtec on action ,car would hold down at vtec for a while , like stays at 6000rpm for 5 seconds before it move over , after a while of getting vtec on action , the car would heat . It goes back to normal or won't heat if I didn't put vtec on action , even while car stop , it never heat. Also rpm keep going up and down 100~1000rpm when turning AC on.
I replaced radiator from half/small to full or big one with 2 fans , but still heating , at same rate as the small one.
For turbo , I need a guide on what will I need to change/replace ( that not included with turbo kit) on my car to get it to work probably. My brother had just installed turbo on H23 Prelude , but whenever he accelerate , his car would push back and forward , like chocking, we followed the equipment , but everything seems to be fine and normal , also it would heat up after short time ( 5 min or less ) , his car moves fine if he accelerate slowly and, won't heat , or heat a bit slowly .
Is this heat problem normal with H series engine ? The temp here is 25~45c at summer . If this an issue ?
I don't want to waste ~600$ on turbo kit and time to end like my brother prelude xD
Sorry for talking alot.
Thanks in advance.
I can provide info , pic or charts of needed just ask Sorry I have a lil knewledge about cars details .
Old Apr 21, 2012 | 11:18 AM
mouab18c1's Avatar
Default Re: Need help installing Turbo on H23 , 95 intergra , but troubles.
Take it to a shop or someone who knows what they are doing. I don't even understand what you just said.
Old Apr 21, 2012 | 12:05 PM
I did , no one have any idea , how or what causing this.
Please which part you did not understand , so I can explain better.
Sorry for the bad explaination , as some motors matters/definitions are vary from area to another.
Old Apr 21, 2012 | 02:54 PM
6dmnbg's Avatar
H23 motors are non vtec unless you actually have the blue top motor, do you? I had a similar problemin my 93 prelude si which had a h23 non vtec motor. Everytime I would turn on myhead lights my teperature guage would shoot into the red but the car was not over heating. My problem was that the ground for temp sensor and headlights are the same and the bolt was loose. Quick easy fix but took a very long time to figure it out. That same prelude I later boosted it with a h23 bottom block with h22 head then later with a jdm h22 type s motor so I can help you with turbo questions.
Old Apr 21, 2012 | 03:12 PM
Yes , my engine has the blue cover , it does over heat as the water flood over with a stutter , it's only over heat when AC and push car on vtec +5000/rpm for a few kilos, if I keep it below vtec range -5000/rpm or stop car , temp would drop back to normal.
I will record video tomorrow on how car act .
Can you please tell me what will I need to change or replace for installing a turbo ? My brother bought a turbo kit and installed it on his H23 vtec, but car won't accelerate and keep pushing back and forward. Like jump forward on about to accelerate, then hold back , it keep doing that , but it move ok if he accelrate slowly. I think something is missing , I will get a pic , maybe you can tell me what is wrong
Thanks.
Old Apr 21, 2012 | 03:43 PM
6dmnbg's Avatar
As far as your water temp you need to make sure the condenser fan turns on when the ad turns on. you should have two radiator fans behind your radiator when the ac is on they should both be working. For your brothers car is his a prelude or integra? Does he have a tune or not? sounds to me like the motor is mis firing or is detonating.
Old Apr 22, 2012 | 10:03 AM
Yes , both fans are working probably , when ac is on , it never heat while stopped or below vtec range . But I think it related to something els , I recorded videos on how car behave.
Here when turning ac on and off , you can see how the rpm goes up down , and back to 1000/rpm when ac off.
http://www64.zippyshare.com/v/99578692/file.html
If player didn't play , download file please ( click download on the right ) , their server can be down sometimes.
And this video how sometimes my rpm pause for few sec on vtec, it is more obiviouse and stutter if ac is on. Usualy followed by heat goes up.
http://www65.zippyshare.com/v/57280814/file.html
Please note : the red indicator of ( Hot engine ) on the left , tells me when vtec is active/work , the person who installed vtec , made this so can I know if/when vtec is working.
At winter I used to push car to 160~170/kmh at 3rd gear and can get it over 8000/rpm , no problem , but now it barely reach 140/kmh at 3rd , it become heavy and can't go over 7000/rpm.
I didn't get brother prelude pic for the turbo installation yet . But he said it has his old injectors from his F20 engine , he replaced his engine to H23 when installed turbo , can this be making the hold back issue ?
Thanks.
Old Apr 23, 2012 | 05:11 PM
So ... Any ideas?
Old Apr 25, 2012 | 02:08 AM
I guess no one can help ?
I think I will have to depond on guessing , and throw money on replacing parts a time ...
At least a guide for the turbo ?
gearhead818
Mar 22, 2010 07:18 PM
THC07
Jan 22, 2009 07:44 AM
PetroGuyX
Apr 27, 2003 06:34 PM
sexyaccord
Aug 1, 2002 07:33 PM
