5th gen - cross joint drive
As stated above. I need any specifications available: number of teeth, roller diameter, type of a roller, type of bearing, general dimensions... Any other honda using the same part? I can't dismantle mine right now, so I'd really appreciate if someone could help me...
You might want to specify what car/engine you are talking about and clarify what a 'cross joint drive' is. You mean the 'Half shaft' that goes from tranny to driver side wheel?
Yes. Sorry, I'm not sure of the English names for parts... I meant the inside of the inner CV-joint.
http://www.google.pl/imgres?q=honda+...w=1280&bih=801
It's called a "spider" in this picture...
btw, I drive f20a...
The main body of my CV-joint is ok, but rollers in the "spider" got loose and make click-click noise while moving off. Some aftermarket parts of this kind are available here but I'll have to show the item so the guy can compare... Thanx for bothering.
That pic doesn't work, but I think I know what you're talking about. Might want to pick up an extra CV joint to take those measurements...I don't know where to find them personally.
starbai
Apr 8, 2009 03:16 PM
