98 integra main fuse box giving power to ground??
Old Apr 21, 2012 | 09:03 AM
dc2nerz's Avatar
Default 98 integra main fuse box giving power to ground??
hey im new to this but i really need some help.... i in the middle of a wire tuck but i ran into a problem.i connected my wire harness to the engine and when i touch the engine to the engine bay it spark up. i grab a tester and found out my engine has power running through it.i went back to were the beginning under dashboard .and so far this is what i have. i connect the main fuse box to the batt. with the switch off nothing flows if i turn on the switch the wire harness ground gets power and the problem should be coming from the passenger side i dont know were to go from here i need someones help
Old Apr 21, 2012 | 10:13 AM
B20ztek's Avatar
Default Re: 98 integra main fuse box giving power to ground??
You probably have your 2 power wires mixed up, the power wire that goes straight to the battery goes on the left/top post, and the engine harness power wire goes on teh one to the right/bottom.
Old Apr 21, 2012 | 12:38 PM
dc2nerz's Avatar
no i have it connected the right way as in the pic. now i discover that i have power to the frame of the car.when i put my tester from ground on the batt. and the tip tp the inside frame or anywere metal it lights up.
Old Apr 21, 2012 | 01:28 PM
Black_horse's Avatar
Maybe something els is touching and giving power , I found that the 12v wire of my radio was melted inside the radio bay on the metal. Lucky the fuse saved my car .
This can be serious danger , try disconnecting some wires , or remove a fuse each , till you lose the power then track that fuse wire/source .
I don't know just an idea , hope it can help.
Remove battery power after you leave your car. Till this is fixed
Old Apr 21, 2012 | 01:57 PM
dc2nerz's Avatar
so basically what i did is i open the fuse box from the picture above and disconnected one by one there is one of the plugs that makes my bay power and from those 10 wires 2 make a click click sound im guessing one of those wire is making contact with ground
Old Apr 21, 2012 | 03:25 PM
Are all fuses inside the car unplugged ? The fuses box under the driving seat.
Wich wires do make clicking sound ? Point their numbers from the pic.
A fast suggestion remove all fuses above and keep the power ( T1 ) only , do you still get power on bay?
Old Apr 21, 2012 | 04:01 PM
dc2nerz's Avatar
i removed all the fuses and now there is no power to the engine bay what does that mean
Old Apr 21, 2012 | 04:02 PM
dc2nerz's Avatar
im going to put one fuse at a time to see wich one gives it power
Old Apr 21, 2012 | 04:06 PM
dc2nerz's Avatar
the picture above is not the same as the one i have
Old Apr 21, 2012 | 04:23 PM
dc2nerz's Avatar
and fuse 42 is the one that when i put it back it gives power to the bay
Old Apr 22, 2012 | 11:19 AM
I don't know what that 42 fuse is for , couldn't find diagram for that model , check what the fuse refer to , then track that source wire , or first open and check the fuse box , make sure that fuse slot is not touching with something els.
Old Apr 22, 2012 | 12:00 PM
B20ztek's Avatar
42 is the 100amp battery fuse
Old Apr 22, 2012 | 09:53 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
not making fun of you in any way, but you don't seem to have a lot of electrical knowledge, is there anyone you know from here who could help you? it sounds like you've got a mess, sometimes it's not a bad thing to admit you are in over your head, I would help you if I was nearby, I could probably figure this out quick, but it's hard to do over the net
Old Apr 23, 2012 | 03:13 AM
I agree with lost, if you are confused and lost on what to do , try asking specialist , that what I do It's hard to judge on the net without examing or seeing it.
For what B20ztek said , if it is the battery fuse , and you get power by only plugging it , I beleive it when provide power to T101 , something in that track give power to bay.
That what I think.
Old Apr 23, 2012 | 05:52 AM
fcm's Avatar
fcm
Old Fart
You have a grounding problem, check/redo the main grounds, [batt. to chassis and chassis to engine]
On a DC circuit if a meter or test light indicates power on what should be a ground, engine block, cars frame/chassis it is because there is no ground, you are reading the power on the other side of a load. 94
Old Apr 23, 2012 | 06:49 PM
dc2nerz's Avatar
Ok thank-you to tus last post thats what i needed to know.one quick question i
Deleted the abs on my car should i remove it from the harness
Old Apr 23, 2012 | 07:08 PM
fcm's Avatar
fcm
Old Fart
The whole point of a tuck is to get rid of any wiring you do not need and hide the rest.
Have you redone your main grounds yet? 94
Old Apr 24, 2012 | 06:00 AM
dc2nerz's Avatar
Not yet i went out and bought another harness because i thought thats what was wrong but it keeps doing it so im going to put everything back and then ground my chasis and my engine and all go from there. Should the ground cable for the engine harness have power running through. As well?
Old Apr 24, 2012 | 11:22 AM
fcm's Avatar
fcm
Old Fart
No grounds should have power running through them, however, if a ground lead is not grounded when tested it will show power, as mentioned, you are "seeing" the power that is on the other side of the load the ground is for.
Technically it is the other way around, but that's a diff. story, DC circuits are common ground, so power from the batt, runs to the load, [lets say the dome light is the load] then the door pin switch supplies the dome light, [load] with a ground, the light turns on, if you remove the pin switch and test the lead, it will test as power, once you ground the lead it will test as a ground.
Make sure there is a ground cable running from the batt. neg.(-) to the cars chassis, stock location is under the batt. "box" the ground cable then continues to the engine.
It makes no diff. how you do it, as long as both the cars chassis and the engine are grounded back to the batt. neg.(-), remember all the wiring harness grounds are grounded to either the chassis or the engine, so if either one is not grounded back to the batt. any harness that is grounded to either one will test as power, even any point on the engine or chassis will test as power. 94
Old Apr 24, 2012 | 04:23 PM
dc2nerz's Avatar
Yeah when i grounded the batt to the chasis all my ground lost power
Old Apr 25, 2012 | 08:23 AM
dc2nerz's Avatar
ok so connected the wire harness,and the engine harness. and grounded my chassis and the engine all i id was connect the under dash harness with out putting the dash board back on and i tried to to turn it o but nothing happens theres power but it just makes sound like something turn on but when i flip he switch to turn it on there nothing happening doesn't even make the attempt to start..
Old Apr 25, 2012 | 11:23 AM
fcm's Avatar
fcm
Old Fart
To eliminate the starter, starter solenoid and start circuit as the problem do a bypass jump and test the starter circuit...https://honda-tech.com/forums/showth...cm+bypass+jump 94
Old Dec 28, 2021 | 08:45 PM
baron232323's Avatar
I have a 30 amp in slot 42? Is that bad?
dc2nerz
19
Apr 21, 2012 06:57 PM
caliskier
Feb 2, 2008 10:44 AM
Si_chRis
Jun 24, 2006 03:59 PM
O RLY
Audio / Security / Video
Nov 3, 2005 07:30 AM
jadugartir
May 22, 2005 01:26 PM
