obd0 DPFI to MPFI mini me obd1
Old Apr 21, 2012 | 08:29 AM
m3kid's Avatar
Default obd0 DPFI to MPFI mini me obd1
alright i know this has been covered alot and iv searched for days now on how to do to this i know how to convert dpfi to mpfi and do the mini me swap and all that only problem im having is the wiring part for the obd0 to obd1 conversion I know how to wire the obd1 injectors but when i plug in the obd0 to obd1 jumper harness will i need to add the extra wires from the
sub-harnes (pigtail) to my injectors again and not run them to the correct pin out on my obd0 harness? or do i just need to rewire the distributor plugs, wire in the 4-wire O2 sensor and add the wires for the VTEC oil pressure switch and the VTEC solenoid? thats the only problem im having if there is any diagram on how to do this please let me know like i said iv searched everywhere
Old Apr 21, 2012 | 11:13 AM
civickiller's Avatar
Default Re: obd0 DPFI to MPFI mini me obd1
if you complete the obd0 mpfi then when you do the obd0-obd1 youll just have to add 4 wire o2 and rewire dist plug as far as i can remember(i did this 10 years ago)
Old Apr 21, 2012 | 06:30 PM
m3kid's Avatar
but what if my dizzy already has the jumper harness obd0 to obd1 then where does those wires and and along with the other wires? thanks for the response
Zack Gunther
13
Aug 5, 2014 09:04 AM
2_Envy
Mar 20, 2010 04:46 PM
nitewolf
Sep 3, 2007 07:03 AM
jtroy917
Jun 3, 2007 02:54 PM
Novtecdohc
Aug 18, 2005 06:32 PM
