y8 zc swap in 91 si
Alright... I swapped a y8 head onto my zc block and its running but not right... Don't have much power and seems like the timing is probably off.
I'm running it with my a6 dizzy and ecu till I get the ecu harness. Can you get this setup to run smooth? Or is it gona be like this till i get the ecu jumper? Already got the dizzy harness but the dizzy won't work till I swap ecu.
Any info appreciated
Still can't get it running right. Best I can get is advanced I assume (loud *** intake) if I pull the belt off the cam wich way should I turn the cam to retard? Twords the radiator or firewall? Also which way on the dissy is adv/ret?
anotherstar_noz
Nov 2, 2008 06:25 PM
