OBD2B GS-R intake manifold swap question
Old Apr 20, 2012 | 07:41 PM
FF for Life's Avatar
Default OBD2B GS-R intake manifold swap question
I have a 01 GS-R at 48k miles with the stock IAB system. I want to put a Skunk 2 intake manifold on it and get rid of the stock p72 to avoid a check engine light, and have vtec hit at a higher rpm than the GS-R's 4400rpm (its my daily driver). My question is what to do about the ECU . I know that my car has an immobilizer and that if I were to use a USDM p73 i would have to have it programed for my key. I'm pretty sure a JDM p73 would pass emmissions (I live in Arizona) but im not sure if I could run it without a check engine light. What are your guy's thoughts.
Old Apr 21, 2012 | 05:48 AM
NemesisCBR's Avatar
Default Re: OBD2B GS-R intake manifold swap question
what cel are you referring to? I dont know how the immobilizer works in the ecu besides that it works with the key. You wont get a cel on your p72 with that manifold but your low vtec wont do u much good with that ecu either. A jdm p73 would require the same programming as the usdm p73, both being obd2b, right? You could buy a chipped ecu with the immoblizier disabled. I know phearable has that as an option.
Ive got a obd2a p73 on my gsr with iab disabled. No cel. Just mentioning this for reference. Not sure if it helps any.
polishedturd
Dec 4, 2007 08:14 PM
SkIp_Civic_Ek6
Apr 13, 2007 02:11 AM
boosted lude
Sep 1, 2004 03:01 PM
964dgsr
Mar 2, 2004 10:03 AM
whttyper1998
Mar 6, 2002 01:31 PM
