2000 Honda Civic rough shifting
Old Apr 20, 2012 | 03:43 PM
fatcatpaddy's Avatar
Default 2000 Honda Civic rough shifting
I have a 2000 Honda Civic with 4spd auto transmission. It currently has 250000miles on it, A few months ago I noticed when the car is warm the transmission has rough shifts from 1st gear to 2nd. When the car is cold this problem does not occur, what would be the remedy to this problem?
Old Apr 20, 2012 | 03:48 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 2000 Honda Civic rough shifting
Define rough.
Old Apr 20, 2012 | 04:02 PM
When shifting out of first to second under a load it doesnt smoothly shift, it delays for a second and goes into 2nd so hard it can shake the car if under enough of a load.
Old Apr 20, 2012 | 04:04 PM
The Grumpiest
What does the fluid look like? Has the transmission been maintained? Time for a rebuild?
Old Apr 20, 2012 | 04:10 PM
I took a look at the fluid, it looks very old, I dont think anyone has ever changed the fluid or touched the transmission.
Old Apr 20, 2012 | 04:23 PM
redm3turbo's Avatar
drain and fill it 3x times... 3 quarts each time
see how it responds. Ive had a well neglected trans, did a oil change and fixed her right up.
It wasnt at 250k though.
Also the drain plug on the trans is magnetic, see how that looks. Mine was so bad it appeared that I dumped it into anti-seize. Clean it off good.
Old Apr 20, 2012 | 04:24 PM
Alright I will give it a try thanks
Gorge Deharo
Sep 20, 2015 07:44 AM
hellah fresh
Nov 27, 2012 06:01 AM
Novz
Feb 23, 2012 12:28 PM
99ls1z
Feb 23, 2009 08:14 AM
Carolina Tiger
Feb 16, 2008 02:03 PM
