36mm 5lug on ek automatic need help please
I have a 96 cx hatch that is automatic and i installed my jdm 36mm 5 lug conversion. I was told that i could just swap the outer cv axel hub from the 36mm axel on to the d16 auto axel but when i did the d16 axel is to small just spins inside of the 36mm outer hub. So if its possible or anyone has done thiws i would really apreciate the help thanks guys
The outer part of the axle must not be 36mm then. Usually the 36mm 5 lug conversion needs to be done with a dual cam and the correct axles. I've never seen the 36mm 5 lug on a single cam.
TheBeardedMamba
14
Apr 7, 2017 02:07 PM
legomytego
Suspension & Brakes
May 15, 2008 08:46 AM
RhdRicheeee
Feb 16, 2007 05:10 PM
