coolant guages not working
Old Apr 20, 2012 | 08:24 AM
legend99's Avatar
Default coolant guages not working
my factory temp guage isnt working, i know its plugged in. is there a test i can do to make sure its the temp sensor and not the gauge. dont wanna throw parts and $$ at it.
Old Apr 20, 2012 | 08:52 AM
hatch89's Avatar
Default Re: coolant guages not working
get a factory service manual.( google : factory service manual (for your car)) look on page 16-80. it tells how to test all the coolant temp sensor stuff. im on lunch or i would post a pic but dont have time.
GL
Old Apr 20, 2012 | 10:27 AM
jlicrx's Avatar
that would be true if you are using the U.K. service manual, however, in the USDM service manual (which you should be using if the car is USDM), it is on page 23-94 - in this case, the 2 manuals are the same but in a lot of cases they are very different
Old Apr 20, 2012 | 10:51 AM
TearSDMF89dx's Avatar
i always just jump them to ground and see if the gauge moves
Old Apr 20, 2012 | 11:13 AM
legend99's Avatar
ok jumped to ground nothing...so upon investigation i found that i pulled wire out of connection that connects to sensor. so stripped wire back and wrapped around sensor temporarily and YAY it works. off to get a new connector and hook back up the right way.
thanks for the help, i wouldn't have thought about jumping to ground. i think only 1 or 2 strands where holding it together.
Old Apr 20, 2012 | 11:18 AM
glad to be of service
SeraphimKidd
11
Aug 26, 2009 08:55 PM
laughinxxx
Jun 27, 2002 11:33 PM
BigJohn
May 1, 2002 01:05 PM
Pat
Dec 30, 2001 05:31 PM
