Transmission fluid leaking near shift control cable holder
Old Apr 19, 2012 | 11:07 PM
waza8i78's Avatar
Default Transmission fluid leaking near shift control cable holder
2002 V6 Honda Accord Coupe 3.0
Approximately 170,000 miles.
I have leakage near the transmission. The leak is coming from the shift control holder mounting bolt. I saw this leak when I was about to place the jack & wood (no pun intended) under the tranny to replace the front
motor mount.
Please follow link to see pic.
https://picasaweb.google.com/118111316426315849218/Leak?
authuser=0&authkey=Gv1sRgCKjh19qr_br0fA&feat=direc tlink
My last TS fluid exchange was around 20,000 miles ago....and yes, I did it at the dealer. I am a DIYer and have a Haynes manual. It tells you how to remove the bolt and shift cable, but I don't know what to do next.
Is there a gasket/seal that just needs to replaced or is it something really serious? Please help?
THANK YOU!
Old Apr 20, 2012 | 06:51 AM
f1drivr's Avatar
Default Re: Transmission fluid leaking near shift control cable holder
My 1998 Accord EX 4 cyc is doing the samething I'm going to pull it apart today to try find where it 's coming from. I called the Honda shop and ordered a new shift shaft seal for shifter cable it was Part # 91201-PA9-004 cost $4.15 hopfully that will fix it.
Old Apr 23, 2012 | 12:25 PM
waza8i78's Avatar
I'm assuming you had to drain the fluid before taking it apart. Please let me know how everything went. Thanks.
SpazMan
Oct 21, 2014 03:22 PM
steven.shutz
Sep 12, 2012 07:43 PM
Shinghi
Mar 3, 2012 08:37 PM
Badbenz94
May 13, 2011 02:54 AM
