D16Y7 oil pan torque spec
I'm going to replace my oil pan gasket this week and wanted to know what the torque spec for oil pan bolts on a D16Y7 was and what gasket do you guy's recommend getting
For torquing the pan bolts/nuts, hand-tighten 6 nut/bolts. Two at the crank, two at the water pump, and two in the middle of the pan. Then put the rest on, torquing all to 8.7 ft. lbs. in a circular pattern.
O16581724 5 2 5
13
Aug 2, 2005 04:49 PM
