SI Engine Harness Diagram
Old Apr 19, 2012 | 10:24 AM
myEKsedan's Avatar
Default SI Engine Harness Diagram
I've searched and can't seem to find anything. Anybody have a diagram that states which wire colors go for each sensor. Im in the process of tucking the engine harness and need a diagram. The Chiltons manual only has a few wire colors not each individual one. Any help would be appreciated!!!
-Chris
Old Apr 19, 2012 | 11:58 AM
egsleepercivic's Avatar
Default Re: SI Engine Harness Diagram
helms, http://www.helminc.com/helm/homepage...&usg=AFQjCNFpm
PM'd
Old Apr 19, 2012 | 08:06 PM
crx_si-r's Avatar
i make them all the time from scratch. which si are you working with?
Old Apr 19, 2012 | 08:33 PM
Former User's Avatar
http://www.phearable.net/tech/wiring...schematics.gif
Old Apr 19, 2012 | 08:38 PM
crx_si-r's Avatar
OP needs to state which si he is using. EG or EM1?
Old Apr 19, 2012 | 08:54 PM
Very true.
Old Apr 20, 2012 | 04:54 AM
myEKsedan's Avatar
sorry im its an EM1 harness
Old Apr 20, 2012 | 05:59 AM
myEKsedan's Avatar
ttt
Old Apr 20, 2012 | 07:32 AM
crx_si-r's Avatar
what are you having problems with? its simple. peel back some the tape or vynil loom and you can see what the wire colors are. if you want to make a brand new one you will need to make the wiring be long enough to reach from sensor, to the main branch point (i make my harnesses tuck nicely by the black box and oil filter) then make sure the wiring is long enough to reach your current ECU location.
Old Apr 20, 2012 | 07:38 AM
myEKsedan's Avatar
I'm just having problems knowing which plug goes to which sensor. That's all. The whole tucking part is easy as pie!
Old Apr 20, 2012 | 07:44 AM
myEKsedan's Avatar
also the harness has a couple connectors missing so i need to know what wire is signal and which wire is ground.
Old Feb 2, 2015 | 10:38 AM
94eg5squadMD's Avatar
Did you ever find a site that had a diagram ?
Pinner13
Jan 29, 2012 04:36 PM
lsvtek
Nov 3, 2008 10:29 PM
BR
20
Aug 25, 2004 01:05 PM
