Will this clutch work with this flywheel
Old Apr 19, 2012 | 04:59 AM
SFlCrx's Avatar
Default Will this clutch work with this flywheel
Trans is an 88 crx si 21 splines. engine is d16z6 with a ebay f1 8.5 flywheel i want to put a spec stage 3 clutch for an 88 crx trans 21 spline. i'm pretty sure it will work but wanted to double check before i order this.
Old Apr 19, 2012 | 07:27 AM
jlicrx's Avatar
Default Re: Will this clutch work with this flywheel
not going to work - 88 clutches are 200mm diameter - the D16Z6 flywheel is made for a 212mm diameter clutch - the 200mm diameter clutch pressure plate for the 88 won't bolt onto the flywheel made for the 212mm clutch
Old Apr 19, 2012 | 07:37 AM
SFlCrx's Avatar
well this is what is in my car now running.... http://www.ebay.com/itm/EXEDY-OE-OEM...item256b742689
88 si trans on a z6 engine. it says in the description the clutch is 210mm... no specs on the fly wheel.. so i must have a 88 fly clutch and flywheel now in my car if it is running and driving.... so i can just order a new clutch for an 88 21 spline?
Old Apr 19, 2012 | 07:53 AM
jlicrx's Avatar
what brand of clutch are you planning to order? if you just order a clutch for the 88 you will get a 200mm diameter clutch and you need a 212mm diameter with 21 splines
Old Apr 19, 2012 | 08:36 AM
SFlCrx's Avatar
ACT HC2-HDMM
Ash J. Williams
Sep 22, 2012 06:56 AM
matt's hatch
Jan 30, 2010 06:03 PM
jadugartir
Feb 25, 2005 02:19 PM
luvinmyGSR
Jun 17, 2004 08:08 PM
DsMWookie
Sep 18, 2002 09:49 PM
