Brake lights won't work
What up people I got a 1994 civic and for some reason my break lights won't work but all my other lights work I changed the brake pedel switch and changed a relay still nothing what could it be ?
Checked the fuses? how about the brake bulbs? any missing or blown? Is the brake light the only thing not working? if your license plate light along with the instrument light does not work, You have a blown or missing 10A fuse.
if you have a spoiler connected to the brake light, disconnect it temporarily and check to see if the brake lights work, also double check the connections in the trunk. if you installed a new brake switch and all fuses are okay then it has to be a wiring issue.
Toe_fur
Mar 10, 2013 04:44 PM
