innovative mount trouble
I have a 90 crx si and am swapping in an obd1 b16a with hydro lsd trans. I purchased the innovative mounts. Has anybody else used these mounts. I am having trouble getting them to work. First the driver side mount is at such an angle I dont see how it would work. I got the passenger side trans mount all losely bolted up and the oem t-bracket was crammed up in the fire wall that was causing the motor to sit in the bay crooked. The driver side mount was way off. Any help and pics would be very much appreciated.
I have Innovative mounts and they are perfect! Perhaps you need to call Innovative to discuss! Also you need to consider that there are 2 different mount options. 1- B swap with cable trans. 2- B swap with hydro trans.
Make sure you have the correct ones. Good luck!
You have to have a 90-93 cable "T" bracket.
You have to have a 90-93 engine "post" mount.
This has been covered thousands of times and there are even multiple write-ups on this. A full swap won't just drop into place otherwise.
SEARCH!!!...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
SEARCH!!!...
SEARCH!!!...
https://honda-tech.com/forums/showthread.php?t=2769325
SEARCH!!!...
Innovative Mounts are great no issues with them at all...
Canadian_EF
Apr 7, 2013 02:39 PM
