Attempting a wire tuck (issues)
Old Apr 18, 2012 | 02:45 PM
DailyDriven259's Avatar
Default Attempting a wire tuck (issues)
ok so first of all I did alot of research but cant seem to find what im looking for.
so I have a canadian 99 civic and im planning to do a headlight harness tuck(around the fenders). On the driver side harness coming out of the cabin there is a connecter that plugs into the very end of the engine harness, what to people do with that?
I live in Canada and we have DRL(daytime running lights) I have a DRL resitor box on the driver side behind strut tower.. can I just relocate that in the cabin? when the DRL are on the box becomes hot.
I am also relocating my fuse box only problem is what to people do with the alternator wire and the starter wire(battery)
thanks DD
Old Apr 18, 2012 | 04:26 PM
apexi_rsx's Avatar
Default Re: Attempting a wire tuck (issues)
when i did my tuck the plug tht went to the engine harness i pulled thru the hole in the lower shock tower.
Old Apr 19, 2012 | 08:07 AM
ynaffit509's Avatar
clean
Old Apr 19, 2012 | 08:08 PM
crx_si-r's Avatar
as long as you lengthen the wires evenly you should be fine with relocating the resistor for the DRL
rturner
Honda Civic (2001 - 2005)
Nov 3, 2014 10:17 AM
coupedragracing
Aug 7, 2011 06:36 PM
CORE132
10
Jun 4, 2009 09:32 PM
LilCivic04
Mar 8, 2006 12:37 PM
