d15b2 civic wagon. motor wont do anything
Old Apr 18, 2012 | 11:39 AM
Brennidon's Avatar
Default d15b2 civic wagon. motor wont do anything
whats up guys.. a while ago i rear ended a truck in my 89 civic wagon now that its warming up i want to try and get it back on the road. the problem im having is that when i turn the key my motor doesnt do anything. all the dash lights come on the fuel pump primes and the main relay clicks..i can get all lights(headlights / brakes) to work but while im holding the key over to start it nothing happens the motor wont even make a noise. dont hear anything from the starter either.
things ive checked:
ECU(not throwing any codes)
Main relay( the old one still sounds like it works but i replaced it to be sure)
starter( when i turn the key the starter wouldnt do anything so i took it and got it checked out and it works fine)
grounds(all the grounds seem to be fine and have a good connection)
fuel pump( when i turn the key it still primes)
altenator (still works fine)
motor( its not locked up and turns freely)
spark plugs( they seem good but changed them to be sure)
here are some pics of the car after i wrecked it
and this is it now
if anyone has any idea as to what could be the problem please let me know!
Old Apr 18, 2012 | 12:59 PM
91 EF DX's Avatar
Default Re: d15b2 civic wagon. motor wont do anything
The ignition switch might be bad, try using a screw driver to start it at the starter with the ignition switch on
Old Apr 18, 2012 | 01:36 PM
KINGVEM^^ED6's Avatar
Timing belt?
There's a few wagons at my junkyard pm me ill see if I can get the missing parts
Old Apr 19, 2012 | 05:08 AM
Brennidon's Avatar
Originally Posted by KINGVEM^^ED6
Timing belt?
if it was the timing belt wouldnt the motor try and turn over? im not to tech savy with motors so im not sure
Old Apr 19, 2012 | 05:10 AM
Brennidon's Avatar
may have to try that gotta put the starter back in now tho lol
cruzthestreets
Oct 12, 2014 05:16 PM
Mr. LS VTEC
Jan 13, 2012 06:27 AM
Twistedframe
Apr 11, 2007 05:10 PM
hookedonvtec
May 27, 2004 08:17 PM
