since b16 swap...
my heater controls no longer work, I can turn theheater fan on but I can't select where the heat blows, is this supposed to be like this after the swap or do I need to get a new control unit?
there should be no change. my heater core is screwed up, the inlet pipe is cracked, so if i try to hook it up it pukes coolant into my car and onto my ecu wiring....so i don't have it hooked up.
