FS: High Power Turbo Parts, Integra Shell, and More
I’m clearing out all my Honda parts. I’ve been out of the Honda scene for a few years and moved on with life. These are left over parts that I have kept around in case I decide to build another Honda. I’ve moved on and probably would never build another Honda again.
Prices are reasonable, but I’m willing to hear offers. I’m not desperate to sell either, so please don’t make lowball offers. I prefer not to ship the bigger items. I’m located in Portland/ Clackamas Oregon. I prefer local pickup or meet up within reasonable distances for the bigger items.
If somebody is looking to build a high power turbo car and wants the whole package, I’m willing to work out a great deal too. The only thing missing to have a complete running setup is a fuel system. I had one but sold it to a buddy a couple years ago.
Full-Race / Garrett GT3567R. Brand new never used. Been sitting on my shelf for a few years. Capable of 700WHP. Sold!
B18C1 block, fully built. Darton Sleeves, CP pistons, Eagle rods, OEM Honda bearings, Balanced rotating assembly. ARP Main bolts, and head studs. The block was built, ran NA for 500 miles to break in, and the car was parted out. SOLD!!!
JG B16 head. Fully built, port and polished, 5 angle valve jobs.... SOLD!!!
JG Edelbrock Victor-X intake manifold, used to break in the motor for about 500 miles. SOLD
STR 68mm throttle body. SOLD
Skunk2 stage 1 cams. Used for about 1000 miles. SOLDD!!!
AEM 1020 box. OBD2A. Barely used, plastic still on the front. $400
Stock B16 head, complete without distributor Sold!
JDM Gsr transmission with LSD. Great condition. SOLD
Crower Pro Billet rods for GSR blocks. Rods are brand new, never used, but have sat for years. These are not the low end ones. SOLDDD
Big custom made intercooler, made with Vibrant intercooler core, with 3” inlet and outlet. Capable of 700+ WHP. Dimensions are approximately 14” tall and 30” wide. Sold!
Greddy Type R Blow Off Valve, with pipe and flange. $200
AEM ignition box with 8 CBR coils. SOLD!!
OBD1 B16 distributor $100
OEM Type R Valve cover, mint condition SOLD
BDL fuel filter Sold!
Full-Race replica top mount turbo manifold. For B-series. Turbo flange will need to be machine as it was warped when it got welded on. With 3” downpipe, and dumptube. 38mm waste gate flange. SOLD!
Tial 38mm waste gate. Black top. SOLD
Fluidyne 1/2 radiator with slim fan. SOLD
ACT Extreme pressure plate, with Competition 6 puck clutch. Used for 500 miles to break in motor. SOLD
A Ton of -10 black AN fittings, some straight fittings, some elbows, some aluminum weld bungs. Close to 100 fittings. Enough to do a few valve cover breather setups. Give me a list of what you need and I’ll give you the price.
15ft of -12 SS braided line. $50
Greddy Turbo Timer SOLD
AEM Wideband. Brand new SOLD
Dual pillar gauge pod for DCs SOLD
Greddy catch can with Greddy plastic lines. SOLD
Greddy Oil Filter Relocation Kit without lines. $60
OEM Integra Type-R Lip. Painted Silverstone Metallic. $300
Gold Weld Magnum 13" beadlock wheels. Brand new, never used. If I remember correctly, weld made very very limited quanity of these for Honda Applications. $800
Integra SIR-G corner lights SOLD
Turbo Oil Line SOLD
Ball bearing turbo water lines. Includes fittings to connect to turbo, not in the
Buddyclub P1. White with red lip. Brand New Never used. $450
Buddy Club N1+ Full body coilovers. Used for about 3-5K. In great condition. SOLD!!
Megan Racing C and B Pillar Bars. $80 for both.
OBD-1 DOHC VTEC Engine Harness. Virgin, has not been hacked or cut at all. Plug and Play for the guys doing motor swaps. SOLD
GSR Cams $80
Oil line for Greddy Turbo $25
B-series shift linkage $100
GSR strut bar $20
Carbon fiber gas lid for Integras. It's freal carbon fiber over an oem metal lid, not all Carbon fiber. SOLD
3" upgrade downpipe for Greddy turbo setups SOLD
Misc B-series mounts. $20 a piece
Intercooler Piping bends. PM me what you want for price.
Misc Amps $20 a piece
OEM 94-97 Integra corner lights. $20 a pair, I have two pairs.
OEM Type R shift boot. Brand new. I have two of them. $25 a piece
OEM Honda resistor box, used for low impedance injectors. $10
Japanese brand quick release. This is a hex pattern quick release that doesn't have any slop or play like the other quick releases. SOLD
B-series AC Compressor $30
Complete B-series swap motor mounts for EK Civics. $100
JDM EK thin moldings SOLD
A pair of Polk audio speakers. $20
JDM EK side markers $20
GM 3bar Map sensor. Brand new with pigtail SOLD
B-series Starter. They've been sitting around for years. I can't guaranty they are perfect. So I am going to suggest replacing the contacts to have a perfect starter. If needed, I can replace the contacts before purchases. $40 a piece. $70 with new contacts.
HKS air filter SOLD
Black Integra steering wheel with airbag $80
EK Si / EM1 gauge cluster. SOLD
Turbo Oil Line SOLD
GSR Cams $80
GSR strut bar $20
HKS air filter SOLD
I am looking for a couple 10 an fittings. I am looking for 2 male to male 10 an fitting, a 10an 90 degree bend fitting with hose fittings on both sides(if they make them that way) and another 90 degree fitting with female fittings on both sides. Then a straight -10an fitting with hose 10an fitting on one side and female on the other Let me know if you have any of these and thank you
Bump that manifold and down pipe is nice ill hit u up if it doesn't sell by the time i got cash also is the flange a t3?
