95 GSR bogging...feels like it's being held back...need some help!
Old Apr 18, 2012 | 07:58 AM
EricsGSR's Avatar
Default 95 GSR bogging...feels like it's being held back...need some help!
Ok, bought the car about 2 months ago. It's a 95 GSR with about 130k on it. The car has always (since I bought it) given me an issue when at low rpm's it will kind of miss or hiccup. Like if I cruise through a stop sign in second gear at like 1k rpm's. Then the past two days it started acting really weird.
The car doesn't want to rev (in gear) up and accellerate as it normally should. It feels like it's just being held back a LOT. It isn't missing or anything, just feels like the timing has been pulled or something and it's in limp mode...i don't know.
No CEL's...I checked for any stored as well.
Recently replaced, plugs, cap, rotor, wires, and fuel filter. Checked timing as well and it's spot on 16.
Anyone have any ideas? Maybe TPS, CPS, or some other sensor? I have no CEL's so I'm having a hard time thinking it's a sensor.
Distributor maybe? Is there a way to check the dizzy to see if it's working properly?
Thanks in advance guys.
PROBLEM SOLVED! Was WAY out of time. 10 degrees (roughly) instead of 16
Old Apr 18, 2012 | 08:41 AM
cleansi's Avatar
Default Re: 95 GSR bogging...feels like it's being held back...need some help!
try a compression and leak down test
Old Apr 18, 2012 | 09:10 AM
EricsGSR's Avatar
also it runs good till its fully warm.
Old Apr 18, 2012 | 11:40 AM
91_si_b16's Avatar
cat?
Old Apr 18, 2012 | 12:57 PM
EricsGSR's Avatar
Cat is brand new as of a month ago...this just started 2 days ago
Old Apr 18, 2012 | 02:06 PM
01oemTeggy's Avatar
This is completely normal, nothing to worry about second gear at 1000 rpm is too low to produce any power. Thats why it bogs. The more gas at the lower rpm like that will cause it to bog more. Try axcelerating very slowly it will yield better results.
Old Apr 18, 2012 | 02:48 PM
EricsGSR's Avatar
I understand that, this is my 12th honda. It will bog and hesitate throughout the entire rpm range. It feels like a bad cap and rotor would feel. Like its pulling timing. I'm going to check fuel pressure this weekend and try to rule that out.
Fuel pump primes nice and loud, checked all sensor connections, checked for vac leaks...I'm stumped...
Old Apr 18, 2012 | 03:38 PM
EricsGSR's Avatar
I floor it and it basically goes nowhere when this happens...and apparently it's an intermittent problem because half way home from work it ran perfectly...I'm sure it'll do it again...ugh!
Old Apr 18, 2012 | 03:44 PM
steveo135's Avatar
I have a very similar problem... I've been searching for answers for over three years that I've owned the car. Started threads, replaced MANY parts, and rebuilt the engine to no avail.
Good luck to you sir
Old Apr 18, 2012 | 04:13 PM
91_si_b16's Avatar
idk how are your grounds? FPR? maybe test your injectors? o2?
Old Apr 18, 2012 | 04:16 PM
EricsGSR's Avatar
Ugh...not what I wanted to hear lol. Any other ideas?
Old Apr 18, 2012 | 04:19 PM
EricsGSR's Avatar
How can I test the fuel pressure regulator?
Old Apr 18, 2012 | 04:25 PM
fcm's Avatar
fcm
Old Fart
I would do a compression test.
I would check the TPS.
As mentioned, check fuel pressure.
How did you check for vacuum leaks?94
Old Apr 18, 2012 | 05:00 PM
EricsGSR's Avatar
The old carb cleaner sprayed on all vac lines.
How can I check the TPS? Multimeter?
Old Apr 18, 2012 | 06:27 PM
01oemTeggy's Avatar
Originally Posted by EricsGSR
It will bog and hesitate throughout the entire rpm range. ...
Oh you didn't mention that part. That is most defs weird.
Old Apr 18, 2012 | 06:52 PM
steveo135's Avatar
This is kinda my next guess for me.. something fuel related
you need a fuel pressure gauge, but im not sure where you tap onto the system to get the reading
Old Apr 18, 2012 | 08:18 PM
kchungb17a's Avatar
What kind of plugs and wires did you use? Is the distributor OEM?
Old Apr 18, 2012 | 08:28 PM
stowne78's Avatar
the TPS is just a potentiohmeter (pot, or variable resistor), take a meter and measure the resistance as you move the lever. If problem is intermittent then do it several times, the resistance change reading should be nice and smooth, if it is jumpy then replace it.
Old Apr 18, 2012 | 08:34 PM
worx's Avatar
we had a simillar issue with a gsr of ours and we ended up switching the dizzy it fixed it
Old Apr 19, 2012 | 04:34 AM
EricsGSR's Avatar
NGK blue wires and NGK plugs as well...both new and gapped correctly. OEM distributor as well.
Old Apr 19, 2012 | 04:55 AM
EricsGSR's Avatar
Thanks steveO! I'm leaning towards fuel...hoping it is just some bad gas.
Old Apr 19, 2012 | 04:56 AM
EricsGSR's Avatar
Anyone know the part interchangeability for a 95 gsr dizzy? Will any OBD1 Vtec dizzy work?
Old Apr 19, 2012 | 09:24 AM
jdoc325's Avatar
X2
Old Apr 19, 2012 | 12:16 PM
91_si_b16's Avatar
any obd1 vtec dizzy should work. I am not sure but maybe auto zone can test the coil or some thing.
Old Apr 19, 2012 | 01:19 PM
fcm's Avatar
fcm
Old Fart
Butain works better, I just use a Bic lighter, or my Benzomatic torch, turn it on, [without lighting it, da].94
