BIGGEST HONDA RUMMAGE SALE... CLEARING IT ALL OUT..
Old Apr 18, 2012 | 05:05 AM
jimmytime's Avatar
Default BIGGEST HONDA RUMMAGE SALE... CLEARING IT ALL OUT..
Time to clear out space and make room.. I have to much stuff and I need it gone at this point its getting hectic and building up.. I have pictures of everything so just ask if you want a pic because Its like 1000s of pictures and is to much to post. I will always be updating the list also as Im still going through stuff but this is the start of the Rummage sale.
92-95 ex coupe parts
oem hubcaps
front oem strut/spring combos have like 5 sets.
Black rear seats
Black front seats
Full seat belt set black
AC evaporator box
Heater blower box
Full set of door hinges
A-pillars grey
rear trunk panel plastic
winshield wiper motor with linkage fits del sol also
passenger headlight
oem gas cap
p/s power interior door latch
d/s power interior door latch
93 ex firewall power harness
93 ex power d/s door harness no tweeter on this model
93 ex power p/s door harness no tweeter on this model
front speaker panels
front fender outer moldings
black d/s power window switch
black p/s power window switch
rear quarter panel outer moldings
full sunvisor set with clips
d/s REd power mirror
p/s Red power mirror
under dash fuse box with fuses
sunroof assembly
d/s and p/s power mirror block off plates
oem horn
interior inner taillight covers
full headlight / wiper stalk combo
oem clock
oem red gas door
defrost switch X 3
RZ-0132 main fuel relay
full sunroof assembly motor i think is out
power mirror switch
hazard switch
emergency ebrake handle black
dome light one tab broke on lens tough to stay up
cruise control switch
trunk interior light
automatic cruise ECU
interlock control relay
power black door panels
cruise control motor
rear full trunk wiring harness
stock intake tube
climate control with harness
sunroof wiring harness
gauge cluster harness automatic
fuel filter
oem lug nuts
front brake calipers
A/c under dash wiring harness
radiator fan
srs harness
radiator overflow bottle
black d/s and p/s interior door handles/pouches
headlight brackets
p/s window regulator
upper control arm set
89 Civic hatch STD..
4 speed manual tranny
brown carpet
d/s front knuckle
p/s front knuckle
d/s axle
p/s axle
D15b1 oil pan
shift linkage and shifter
D/s front window
D/s rear window
P/s rear window
P/s taillight cracks and chips on it
gauge cluster console brown
oem antenna
glove box bracket
front one piece windshield molding
front subframe reenforcement bar SOLD
passenger side window regulator
inner chassis front moldings
rear window moldings
interior floor harness
brown ebrake console
upper center dash vent brown small crack not seen when installed
dome light brown
PM5 manual ecu
brown door pouches
brown interior door handle pouches
defrost switch
interior grab oh **** handle brown
manual gauge cluster no tach 135K
full door hinges set SOLD
climate control with cables
lugnuts set
front D/s lower control arm
windshield wiper motor
ebrake handle
hood prop/rod
brown interior door handles
d/s and p/s interior door latch
A/c heater core box
clutch cable
steering wheel
D series obd0 alternator
Dual point full intake mani with throttle body and both injectors
yellow gas door lid
Front brake calipers
d/s mirror
D15b1 upper timing belt cover
throttle cable
battery tray
rear seat brackets
D15b1 maual engine harness
D/s headlight super clean
p/s headlight super clean
radiator fan
condensor/other fan
manual gauge cluster harness
radiator over flow bottle
windshield washer bottle
fuel filter with fuel setup
89 CRX
Rear speaker brackets
fuel filter
rear view mirror
interior grab handle blue
2 dome lights
coin box BLACK
front interior door body moldings
DEL SOL
Rear window
Firewall harness
passenger headlight
D/s foglight with bracket
heater blower box
D/s sun visor
under dash fuse box and fuses
trunk molding
black ebrake handle
hood prop
SRS airbag harness X2
5 speed shift **** oem
heater/ac interior harness
tarmac roof shock
black p/s seat belt
hood cowl
rear interior side panels
steering column cover
srs airbag ecu
black trunk hinges
white trunk hinges
cruise control unit
upper steering column cover
d/s master window switch
d/s and p/s power door harnesses for power mirrors
climate control harness X3
interior A/c harness X3
13" oem hubcaps
tarmac roof side plastic trim
d/s and p/s upper door molding
dome light panel
sunvisors set
sunvisor panel
throttle cable
p/s window molding small window
p/s small window
clutch master cylinder and reservoir
blk p/s seat belt
throttle cables X3
oem gas cable
roof warning unit relat X3
inner trunk tarmac release
wiper arms and bolts
oem horn X3
black gas door lid
d/s small window tinted
d/s non tinted small window
lower steering column cover
trunk molding
climate control harness X2
upper dash trim column with switches
windshield wiper regulator
d15b7 AC compressor bracket
srs airbag harness
p/s inner door latch
red gas door lid SOLD
black dome light
grey dome light
96-98 EK parts
oem radio SOLD
obd2 o2 sensor off gsr cat
defrost switch
cruise switch
dimmer switch
outer door moldings
interior lower side panels
map assembly sensor
map fuel sensor
oem cup holder
full grey rear seat belt set
91 civic hatch DX
oem antenna
oem d series throttle cable
black side dash vents
upper control arms
d/s inner door latch
lower center console with ashtray
lower center console with no ash tray
gas lid primed
gas release cable
88 CRX
P/s a pillar black
front brake calipers and pads
oem antenna
oem wiper motor and linkage
automatic pedal assembly
Dash coin box
Full trunk release with cables
rear trunk molding
blue door handle pouches
black p/s interior grab handle
gas/trunk release
MORE 92-95 EG and EJ
blower motor box
dimmer switch X3
defrost switch X2
shifter console brackets
passenger side door pouch black
full set of door hinges
DX hatch SRS wiring harness
mini center sunvisor
hood hinges EG hatch
rear black brake light
gas cap
purple gas door lid EJ1
EX srs wiring harness
EG hatch dome light
P/s taillight coupe
rear seat brackets
gas and trunk release with cables
EG hatch rear trunk latch
cruise motor and cable
coupe hood hinges
power steering reservoir
grey rear brake light
D/s taillight
white gas door coupe
D16z6 intake manifold bare
1995 civic owners manual
D/s and p/s upper control arms
92-96 prelude
Blue full steering wheel with airbag
Black full steering wheel with airbag
rear calipers with pads and ebrake cables
front calipers with pads
5 speed oem shift ****
driver headlight
passenger headlight
amber driver turn signal light
amber passenger turn signal light
black oem floormats
oem 15 inch rims
full black seatbelt set
black spoiler
black rear bumper
black sunroof
silver sunroof
adding more to come..
I will be adding more this is just the start.. also doing a full prelude right now so I have blue and black prelude parts.. pm me since it comes right to my phone with any questions you have..
Thanks alot
Old Apr 18, 2012 | 06:31 AM
hrs-parker's Avatar
Default Re: BIGGEST HONDA RUMMAGE SALE... CLEARING IT ALL OUT..
bump for a lot to stuff
Old Apr 18, 2012 | 06:35 AM
jimmytime's Avatar
thanks for the bump.. sadly its about only half of what i still have to go through...
Old Apr 18, 2012 | 06:38 AM
jimmytime's Avatar
Parts are located in South east wisconsin area also..
Old Apr 19, 2012 | 07:35 AM
jimmytime's Avatar
bump..
Old Apr 19, 2012 | 08:20 PM
vgk414's Avatar
got any del sol rubber seals for door/windows and roof???
Old Apr 20, 2012 | 07:08 AM
JRG151's Avatar
Do you have any front set belts for an eg? If so how much shipping to 19966
Old Apr 20, 2012 | 08:04 PM
jimmytime's Avatar
yes check list for del sol moldings its on there. and yes i have full eg coupe black seat belts and buckles.
Old Apr 22, 2012 | 07:00 AM
jimmytime's Avatar
bump..
Old Apr 22, 2012 | 04:34 PM
gsrvong's Avatar
do you have obd1 gsr distributor?
Old Apr 22, 2012 | 05:24 PM
jimmytime's Avatar
no i dont.. only a h23 obd1 dizzy
Old Apr 24, 2012 | 06:09 PM
jimmytime's Avatar
bump..
Old Apr 30, 2012 | 07:10 PM
jimmytime's Avatar
bump
Old May 2, 2012 | 08:56 AM
jimmytime's Avatar
bump..
Old May 4, 2012 | 05:44 AM
jimmytime's Avatar
bump..
Old May 9, 2012 | 06:33 AM
jimmytime's Avatar
bump..
Old May 15, 2012 | 08:11 AM
hmongrider's Avatar
How much for the prelude wheels? Conditions and tires?
Old May 15, 2012 | 08:17 PM
jimmytime's Avatar
sold them awhile back
Old Jun 7, 2012 | 09:42 PM
steve9927's Avatar
need that e brake cover and a ash try maybe that fog light and some corner lights if you got em for the del sol. im in madison let me know how to get them if you still have them
Old Jun 7, 2012 | 09:44 PM
steve9927's Avatar
and steering column cover
jimmytime
Mar 10, 2013 04:57 PM
jimmytime
Apr 17, 2012 07:55 PM
imonx850
Dec 5, 2010 08:22 PM
_BEN_
Feb 10, 2005 12:30 PM
MIZIKETSK
Sep 6, 2002 06:55 PM
