1992 Honda Civic Hatchback reverse light issues.
Old Apr 17, 2012 | 10:49 PM
spoofmastafly's Avatar
Default 1992 Honda Civic Hatchback reverse light issues.
New to the forums, not to modifying vehicles though. Just bought this hatchback to have something to play around with as my 2010 Mazdaspeed 3 is pretty much modified as much as I can without throwing a bug turbo on it.
Anyway it has a 94 Integra LS engine in it and Im throwing a turbo on it..but that's another thread. My issue is my reverse lights, they work only when all my lights are off. Once I turn my parking lights or headlamps on they shut off. No idea why, just replaced the housing and bulbs. Wires look fine. Any help?
Old Apr 18, 2012 | 04:40 AM
Yo Pintura Trenes's Avatar
Default Re: 1992 Honda Civic Hatchback reverse light issues.
It's either shorting out somewhere or the wires are in the wrong location in one of the pigtails. You are going to have to get a wiring diagram and check all the placements of the wire terminals in the connectors. It might just be a ground issue
Old Apr 18, 2012 | 04:30 PM
Wires are hooked up correctly, as the reverse lights work fine if the other lights are all turned off. They come on when the car is placed in reverse. As for a ground issue, seems to be hooked up correctly. There isn't a grounding wire running to the body just off the pigtail into the wiring harness.
Old Apr 18, 2012 | 09:57 PM
No one else have this issue?
Old Apr 20, 2012 | 02:28 PM
Still can't figure this out. My reverse lights only work when the car is on, and no other light has been turned on.
Old Apr 27, 2012 | 09:58 PM
Still no ideas? The grounds are fine checked them today. None of the wires are hacked up. I pulled the reverse switch on the transmission and held the button down. Reverse lights lit up, whenever the running lights or headlights are turned on the reverse lights turn off still. No idea what is causing this, the service manual doesn't say much in helping with this issue either.
99ej6gsr
37
Nov 16, 2010 11:04 AM
esp4life
May 9, 2005 08:38 AM
Giga Crusher
Apr 25, 2005 10:37 PM
calel
Oct 24, 2004 04:31 PM
