FS/FT B17 Cams/B16A/B18C Small List..Pics
Got Some Parts Forsale or Trade
Names Zack Located North Weatern,PA Phone Number to Txt 724-984-2168
Looking For
CTR Crank Pulley
1. B17A1 GSR DOHC VTEC CAMS...Mint Condition...$75.00 Shipped or trade
2. B16A OBD1 Throttle Body.../With Map Sensor on Top..No FIV....$75.00 SHIPPED/With Map Sensor&TPS
3.B18C OEM Oil Squirters...$25.00 Shipped
4.B16A2 99SI EM1 OEM Cam Shafts...78k Miles...$60.00 Shipped
5.Resistor Box NONE eF PLUG $25.00 Shipped
6.91 Toyota Supra 3.0 Turbo 440cc Injectors...Was Sent And Cleaned &Tested...Had In my Civic For 600 Miles Top Since Cleaned...They Worked Great&Have a Great Spray Pattern....$120.00 Shipped Obo
7.B18C1 OEM OIL COOL...Oil Sandwich...Hoses/Thromostate Tube/Housing $100.00 Shipped
8.02 RSX TYPE-S Rear Leather Seats...Super Minty Clean...$120.00+Shippig
9.SRP 81.5mm B-Series Forged Turbo Pistons 9;5;1...Under 3,500 Miles...Skirts are Perfect...Needs New Set Of Rings...$315.00-$305.00 Shipped PRICE DROPED
10.Manuel Boost Controller...Not Sure Of Brand But my buddy Paid $65.00 For it ....$35.00 Shipped Obo
11. DSM Black Top 450CC Injectors...Injector Resistor Box Included...Just Came Out Of Turbo Civic For BiggeR Injectors..Work perfect...$125.00 sHIPPED 4 INJECTORS&Resistor Box
12. ECUS ....
~P06 OBD1 Ecu...Converted To VtEC&Data Logging Porte...And Chipped/With EasySnap Out Chipped Not Pull Out ****...$130.00 Shipped
P06 OBD1 5 Speed ECU...Virgen ...$70.00 Shipped
PM6 OBD0 5 SPEED ECU...$60.00 Shipped
p2p obd2 5 speed Ecu..$60.00 Shipped
P2E OBD2 AUTO Ecu....$50.00 Shipped
P07 OBD1 5 Speed Ecu...Has Burnt 1&4 Injector Resustor In Ecu...My buddy Said its Easy
13.Knock Sensor...Fresh Was Replaced Not Long Before i Got Motor $52.00 Shipped
14.92-95 grey dash trim piece..$40.00 Shipped
15.OLD School accord Big Face Shift ****..$12.00 Shipped
16.92-95 Civic Climate Control Unit..A/c to...$45.00 Shipped
17.f22 nON Vtec Valve Pan Cover Was Sand Blasted...$40.00 Shipped
18.92-95 Civic Front Wiper Motor Assembley And Motor...Worked Perfect...$55.00 Shipped
19.B16 IVAC Good Conditon Came off Low Mile Motor...$55.00 Shipped
20.Wiseco Forged 81mm Pistons...9:6:1 Im or Maybe Little Lower...Allows Clearence For 1mm Oversized Valve Also...Used For 5,000 Miles..1 Piston is Brand New I Replaced It Because Other One Had Got Beat Up From Dropped Valve But all 4 Pistons Are Perfect Now...Also Have All 4 Wrist Pins..Upgraded Ones....And Clips...4 Sets of Brand New Rings...The Rings/1 New Piston Cost me $224.00 Alone Asking $400.00
21.TURBO XS RFL Blow Off Valve...Perfect Condition...Offical One To...Does Not Include The Pipe Or Flange...But a Flange For it On Ebay is like $10 Bucks shiped.... Asking $105.00 Shipped If Interested Will Get bETTER Pictures..
22.94-up Integra OEM Over FLow...$12.50 Shipped /94-up Integra OEM Gauge Cluster Bazel..$25.00 Shipped
23.B16/B18/B20 HYDRO BRAND NEW PRESSURE PLATE...OEM REPLACEMENT...$55.00 Shipped
24.94 integra OEM CLOCK $15.00 SHIPPED
25.94 INTEGRA LS 14" HUB CAPS ...ALLL MINT...$50.00 SHIPPED
26.88-91 CABLE D-SERIES REAR BRACKET..$35.00 SHIPPED
27.B-SERIES Passenger Side Inner Hub Part...Was Off New axle....$30.00 Shipped
Looking For
CTR Crank Pulley
12. ECUS ....
