Timing belt
Old Apr 17, 2012 | 08:42 PM
Zac W.'s Avatar
Default Timing belt
Just replaced my belt on my 96 LS. Question is, what's the worst that can happen if my belt is too tight?
Old Apr 17, 2012 | 08:47 PM
AdamMRTwo's Avatar
Default Re: Timing belt
To much pressure on the pulleys can cause the bearings to go out prematurely I believe.
Proper tension from this walk through, "there should be about one inch of deflection on the longest run"
http://www.clubcivic.com/board/showthread.php?t=37920
famous323's Avatar
use some logics, too tight= premature wear!
Old Apr 17, 2012 | 08:51 PM
famous323's Avatar
there would be more wear on the belt, the pulleys and tensioner are stationary the tension pulley spring isn't under that much load.
Old Apr 17, 2012 | 09:38 PM
Zac W.'s Avatar
I assumed pressure on bearings... Was kind of hoping the belt will stretch a tiny bit. Thanks for the replys
Old Apr 17, 2012 | 09:56 PM
racebum's Avatar
broken cams are what usually happens. may take months but tight belts are a big cause of it
if you tension it as designed there is no problem. if you add "extra" tension, cams are at risk.
it's also hard on the belt
Old Apr 17, 2012 | 10:00 PM
famous323's Avatar
if you don't mind me asking why are you running it so tight to begin with?
Old Apr 18, 2012 | 05:00 AM
TheRealTegger's Avatar
Belt will break.
Old Apr 18, 2012 | 05:47 AM
fcm's Avatar
fcm
Old Fart
Originally Posted by TheRealTegger
Belt will break.
Agreed.
Unfortunately, if it was just the belt it's not that big of a deal, the problem is "when" the belt breaks, at a start up or at a high RPM shift at high speed, now that truly would be a problem. 94
Old Apr 19, 2012 | 02:08 AM
Zac W.'s Avatar
I put a new belt on it before I put it into the car. I can move the belt maybe 1/2 in. I'll try to loosen the tensioner bolt through the engine cover.
Old Apr 19, 2012 | 10:02 AM
racebum's Avatar
how did you tension it? 1/2" of deflection is about right on the long side. this is kind of a dangerous thread since it's all guess work.
long story short, install the belt just like the book says so and run it
Old Apr 19, 2012 | 01:01 PM
NONvtecLSteg's Avatar
faster wear
Old Apr 19, 2012 | 08:38 PM
Zac W.'s Avatar
When the motor was out I just manually slid the tensioner to when the belt was tight. It wasn't banjo string tight when I set it. Lol. Long side?? By this do you mean the side closest to exhaust manifold?
ShortyzKustomz
Jan 12, 2008 09:56 AM
wakethatassup
Nov 13, 2003 06:30 AM
TodaSi
Jul 16, 2002 03:06 PM
blayzenazn
Feb 18, 2002 07:51 AM
Lei Siew Long
Oct 2, 2001 02:17 PM
