ls vtec??? HELP?!?!
Old Apr 17, 2012 | 07:52 PM
efstunnin's Avatar
Default ls vtec??? HELP?!?!
ok so i picked up a crx with a b20b block and a b16 head
looks like they did the conversion but idk if it as done correctly
i just took the head off today and the dowel pins are there but i couldnt tell if they blocked off the other port
also idk if they used higher comp pistons..the pistons look fresh and in really good condition
if abyone can help...please do
Old Apr 17, 2012 | 07:56 PM
stowne78's Avatar
Default Re: ls vtec??? HELP?!?!
What is it you need help with? If the port on the head is plugged then you should see a plug threaded into it....
Old Apr 17, 2012 | 07:58 PM
efstunnin's Avatar
then i dont think its plugged..this is my first ls/vtec motor so im confised and just wanna make it work.i dont remember seeing a plug in there and do you know which hols is supposed to be plugged. also if the pistons arent after market will it still run for a while or blow. cause i keep reading about the aftermarket pistons
Old Apr 17, 2012 | 07:59 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Well since you can't really listen or ask good questions take pictures. We will be able to help you then.
Old Apr 17, 2012 | 08:07 PM
efstunnin's Avatar
which hole needs to be plugged
Old Apr 17, 2012 | 08:14 PM
famous323's Avatar
1 second search on google got me this...
Old Apr 17, 2012 | 08:19 PM
efstunnin's Avatar
thanks man.
now does anyone know if the stock pistons from a b20 will hold up
Old Apr 17, 2012 | 08:22 PM
famous323's Avatar
yes but upgrade your rod bolts to arp
Old Apr 17, 2012 | 08:26 PM
efstunnin's Avatar
word. and i have a pr3 obd0 ecu chipped to go with it but i was gonna run obd1. should i try to keep this ecu or get a p28 chipped?
Old Apr 17, 2012 | 08:30 PM
famous323's Avatar
either one is fine use the one that is the least cost effective to you and get a good tune.
Old Apr 17, 2012 | 08:38 PM
efstunnin's Avatar
cool thanks.
Old Apr 17, 2012 | 08:55 PM
famous323's Avatar
cool thanks.
np, if you're still in doubt post some pics we can identify your pistons and head work if need be.
Old Apr 17, 2012 | 09:03 PM
efstunnin's Avatar
ill post some up tomorrow afternoon
Old Apr 18, 2012 | 03:45 AM
jdmboyef9's Avatar
IMPORTANT!!! Does it have an oil feed steel braided line running to the back of the head on the distributor side? If not DO NOT start the motor it will blow up instantly. The hole you plug on the head is normally the oil line, without the new line added there is no oil circulation in the head or engine which is very very bad
Old Apr 18, 2012 | 12:55 PM
efstunnin's Avatar
yes it already has the line set up and everything..ill post some pics right now of evertthing
Old Apr 18, 2012 | 01:15 PM
efstunnin's Avatar
https://mail-attachment.googleuserco...cdq5aeIHtXZFzs
efstunnin's Avatar
https://mail-attachment.googleuserco...4A65siDEzebVew
Old Apr 18, 2012 | 01:28 PM
4drEF's Avatar
Keyboard Humorist
I'm having trouble reading that.
Can I get your username and password to your Google mail account?
then I'm sure to be able to view files, like the one you linked to, that are located in your personal email folder.
Old Apr 18, 2012 | 01:43 PM
efstunnin's Avatar
Old Apr 18, 2012 | 02:01 PM
efstunnin's Avatar
ill try and post em again but im not gonna give you my email info
Old Apr 18, 2012 | 02:07 PM
efstunnin's Avatar
<a href="http://tinypic.com?ref=30digw5" target="_blank"><img src="http://i41.tinypic.com/30digw5.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old Apr 18, 2012 | 02:08 PM
efstunnin's Avatar
Old Apr 18, 2012 | 02:10 PM
efstunnin's Avatar
Old Apr 18, 2012 | 04:00 PM
jdmboyef9's Avatar
The hole on the bottom left needs to be tapped and plugged
Old Apr 18, 2012 | 04:57 PM
crxin's Avatar
Yea nothing in that head is plugged. You can find kits with the sandwhich plate, the steel line and fittings, the tap, and the plug online for like 150 bucks or something.
something like this.
http://www.robearracing.com/pd-golde...lsb20-vtec.cfm
