OEM Foglight Question
Old Apr 17, 2012 | 05:41 PM
90DB1TegSedan's Avatar
Default OEM Foglight Question
i have a 90 integra and has the stock fog lights
my question is that is there a way to make the fog lights turn on by themselves without having to turn on the headlights
Old Apr 17, 2012 | 05:58 PM
TunerN00b's Avatar
Default Re: OEM Foglight Question
1) Not as wired from the factory. Absolutely if you're willing to add a switch and wires.
2) Running them that way is illegal in the US, if that matters to you.
Old Apr 17, 2012 | 07:00 PM
i have been seeing around and hear alot about taking the power wire from the fog light and run it to a spot on the fuse box and did it and worked for like a sec and went out dont know if i blew a fuse..but would like to use the oem switch
Old Apr 18, 2012 | 06:19 AM
fcm's Avatar
fcm
Old Fart
Simple, pull the fog light switch, cut the red/yellow lead going to it, extend the lead from the switch long enough to reach the under dash fuse box, don't forget to cap off the other cut end as it is hot when head lights are on.
Now find the park light or the 2nd ign. "free pin" on the under dash fuse box and plug the extended fog light switch lead into the free pin.
Your done, the fog lights can be turned on as long as park lights are on ,[park light free pin] or when ign. is on and you can't forget them on. 94
Old Apr 18, 2012 | 07:43 PM
does the second ing "free pin" have a fuse?
cause i was free handing it like a idiot and it worked when i made contact then it went out and that pin doesnt work anymore so idk if the fuse to it blew or something
Old Apr 19, 2012 | 05:40 AM
fcm's Avatar
fcm
Old Fart
The only thing on your car that is not fused is the batt. lead to the starter motor, everything else is fused.
Which free pin did you use?
Is anything else in the car not working?94
Old Apr 19, 2012 | 06:10 AM
TheRealTegger's Avatar
Another simple method of independent fog-lights on this car:
1) disconnect battery neg terminal;
2) pull red/yel wire at fog-light switch and blank-off so it can't short-out (always best to simply pop the pin out of the body rather than cutting the wire);
3) tap into red-wht wire at fog-light relay, and run a new line to where the red/yel wire was on the fog-light switch;
4) reconnect battery.
Now both the relay and the switch are powered through the #19 fuse. You'll need to remember to turn the fog lights off when you leave the car.
Old Apr 19, 2012 | 12:45 PM
keeping_secrets's Avatar
If you plug it in the right spot you dont need to worry about turning them off. Mine shut off when ever i shut the car off so i dont forget to turn them off.
Here is my db1
Old Apr 19, 2012 | 01:14 PM
fcm's Avatar
fcm
Old Fart
Here is my db1
Ditto that, are you using the 2nd ign, free pin or another ign. source?
Old Apr 19, 2012 | 01:20 PM
Yeah I'm using the 2nd pin. I didnt like having them stay on all the time
Old Apr 19, 2012 | 01:24 PM
fcm's Avatar
fcm
Old Fart
Looks like you need a set of front sidemarkers, or is that an old pic?94
Old Apr 19, 2012 | 02:30 PM
its the one in the pink connector...when i first plugged in it worked for like 4 sec then shut off...and all the other connectors turn on my headlights..
Old Apr 19, 2012 | 02:49 PM
Yea it was kinda old. I have new side markers now and a white fender due to the fact that my old one was all dented.
Heres a more recent picture from a month ago
Old Apr 19, 2012 | 04:12 PM
fcm's Avatar
fcm
Old Fart
What do you mean, all the other connectors turn on the head lights? 94
Old Apr 19, 2012 | 05:49 PM
if i connect that connector to any of those 3 empty slot my headlights turn on..only that one where it is there now is when it had gotten the fogs to turn on
Old Apr 19, 2012 | 06:29 PM
fcm's Avatar
fcm
Old Fart
OK, so where is the white wire with the pink connector coming from?
It should be the fog light switch side cut end of the red/yellow lead, it sounds like you have connected the harness side of the cut red/yellow lead, [that if you put power to would turn on the head lights, [low beams], unplug the pink connector, turn on the head lights and test that white lead for power, if it has power when head lights are on, say DOH! and find the correct lead to extend and plug into the free pin. 94
You did cut the red/yellow lead and did not reconnect it, right?
Old Apr 20, 2012 | 10:41 AM
definitely DOH
i was connecting the cut part to the pin lol did it the right way and worked now thanx again!
Old Apr 20, 2012 | 11:03 AM
fcm's Avatar
fcm
Old Fart
Your not using the park light free pin, [I do not see the park lights on] so are you using the 2nd ign. free pin or the 12V constant free pin, [not a good idea]?. 94
Old Apr 20, 2012 | 11:39 AM
i am using the second ign free pin
is that not good?
Old Apr 20, 2012 | 12:51 PM
fcm's Avatar
fcm
Old Fart
Yes, that will work, you can't forget and leave the lights on. 94
Old Apr 20, 2012 | 01:19 PM
they turn off when i turn the car off its all good
mvp40
Jan 23, 2012 07:38 PM
dyce_b17
Aug 23, 2011 05:37 PM
jelyman
Jul 25, 2010 10:10 PM
SupaMonkey
Sep 16, 2008 04:07 AM
bigedx
Jan 1, 2004 02:01 PM
