D16Z6 Engine Rebuild "Bearing Help Please"
Old Apr 17, 2012 | 02:50 PM
CaliforniaDad's Avatar
No-Traction = Fun
Default D16Z6 Engine Rebuild "Bearing Help Please"
I'm rebuilding a D16Z6 right now and I'm having clearance issues with the number 4 rod bearing. The rod is marked "3" the crank is marked "B" Using the honda bearing guide is says a "3-B" is green. When I use a green bearing, torq it down the 23ft lbs my plasti-gauge reading is .0001 way too tight. Please Advise.
Old Apr 17, 2012 | 03:28 PM
No-Traction = Fun
Default Re: D16Z6 Engine Rebuild "Bearing Help Please"
What bearings do I need to get to the proper clearance? I tried yellows and still too tight.
Old Apr 17, 2012 | 04:52 PM
No-Traction = Fun
Also noticed this engine has P08 pistons in it (D16Z6) I have another stock (d16Z6) and it has P028 pistons. I'm confused please help.
Old Apr 17, 2012 | 07:43 PM
No-Traction = Fun
Boy whoever installed built this motor installed the rings upside down too......Gosh!
Old Apr 17, 2012 | 09:05 PM
apexi_rsx's Avatar
they dont sell in the color code anymore. most of the aftermarket bearings are the green ones.
Old Apr 17, 2012 | 09:12 PM
Dc4LsTeG's Avatar
EK9
?? OEM Honda bearings are sold by colors
As for clearance you mean your at .001" and not .0001" correct?
And have you done the measurements using the correct tools or are you just plastiguaging?
Old Apr 17, 2012 | 10:05 PM
No-Traction = Fun
Yeah my bad .001 and just used platigauge. the other 3 came out at .015"
Old Apr 17, 2012 | 10:53 PM
rich7777's Avatar
Californiadad, try taking those bearings out and giving the backs along with the journal a good clean down. Make sure the bearing is completely dry to. Let me know...
Old Apr 18, 2012 | 12:40 AM
rich7777's Avatar
What did the yellows come out at?
Old Apr 18, 2012 | 07:18 AM
No-Traction = Fun
The yellows seem to come out the same .001" I'm wondering if there is a defect in the rod.
Old Apr 18, 2012 | 07:49 AM
No-Traction = Fun
Also will the P08 pistons cause any ill effect in the engine VS the P028 pistons?
Old Apr 18, 2012 | 07:52 AM
idreamidrive's Avatar
You could also do it the VW way and if it spins around the crank freely only one time around with a hard toss, the clearance is perfect.
Old Apr 18, 2012 | 08:06 AM
No-Traction = Fun
Hahahha....funny
Old Apr 18, 2012 | 08:10 AM
Dc4LsTeG's Avatar
EK9
Sounds like you have a problem with the rod or crank if your getting the same clearance with different size bearings. Do you have access to a mic and dial bore gauge?
Old Apr 18, 2012 | 08:54 AM
No-Traction = Fun
I do have a Mic but no dial bore gauge. I'm going to take it to the machine shop and have them resize/check the rod. Because all other 3 rods came out at .015" clearance
Old Apr 18, 2012 | 09:10 AM
rich7777's Avatar
You could just polish that one journal. That should give you round about what you need. Have you definatly ruled out what i first said ? x2 different sized bearings should give you a different reading of around .0002.
Old Apr 18, 2012 | 09:12 AM
94EG8's Avatar
Seagull Management
P08 pistons will drop the compression ratio down from 9.14:1 to 8.26:1 great if you want to boost, not so great if you don't. I'd find the right pistons or a set of P2E D16Y7 pistons (they'll up the compression slightly to 9.62:1)
Old Apr 18, 2012 | 09:14 AM
rich7777's Avatar
Hahahha....funny
Look at his avatar if you think thats funny
Old Apr 18, 2012 | 10:31 AM
Dc4LsTeG's Avatar
EK9
Then id at least check the crank journal for that rod with the mic and at least make sure thats in spec and not out of round. Just be careful about having resizing done first unless the rod is out of round because it seems there might be another issue if different bearings are giving you the same clearance
Old Apr 18, 2012 | 11:33 AM
apexi_rsx's Avatar
the piston should have nothing to do with rod bearing clearances. try another rod cap on that rod and see if the clearance changes...
Old Apr 18, 2012 | 12:41 PM
No-Traction = Fun
It was the rod, for some reason it was too tight. So the machine shop re-conditioned the rod back to factory spec. All good now. So using the p08 pistons in this D16Z6, will it be something a normal driver would notice? I'm building this for a customer that is all stock. he just wants something that will last. He is not a racer so think he will be able to notice any difference?
Old Apr 18, 2012 | 12:48 PM
rich7777's Avatar
Hmmmm personally i'd go for the higher compression option. If he does a lot of driving having a higher C/R will improve gas/petrol milage.
Old Apr 18, 2012 | 03:19 PM
94EG8's Avatar
Seagull Management
It's going to be gutless with those pistons in it. You can probably find a good used set of P2E or stock pistons for next to nothing.
Old Apr 18, 2012 | 04:21 PM
No-Traction = Fun
I have another D16Z6 in my garage that i'm going to pull the rods and pistons out of it (p28) and use the rings and bearings off the P08 pistons. Ill have to re-plasti-gauge everything over again to make sure those rods don't interfere with a different crank.
Old Apr 18, 2012 | 04:35 PM
94EG8's Avatar
Seagull Management
I'm pretty sure the rings are different. Same diameter, but I different thickness I believe.
