found metal piece at the bottom of oil pan please help
Old Apr 16, 2012 | 06:34 PM
92eghb's Avatar
Default found metal piece at the bottom of oil pan please help
any ideas on what it is?
Old Apr 16, 2012 | 06:48 PM
Former User's Avatar
Default Re: found metal piece at the bottom of oil pan please help
You want us to guess? POST a picture.
And what car and engine? Give details. Any symptoms?
Old Apr 16, 2012 | 09:37 PM
zerovandez's Avatar
Looks like it could be a relief valve from your oil pump. Is that pan still off? There should be a threaded hole for a plug of some sort. the plug holds spring and this valve inside of the oil pump. Could be the reason why your oil pump is not getting oil to the filter as you mentioned in your other post.
Other possibilities are the block orifice oil control valve. But I'm just guessing.
Old Apr 16, 2012 | 09:45 PM
92eghb's Avatar
It is still off I'll have to check tomorrow but wouldn't there have been other stuff in the pan if that were the case.
Old Apr 16, 2012 | 10:44 PM
v8killaz's Avatar
looks like its the part for the oil pump with the spring in it. doesn't look like an orifice since it has a hollow part for the spring
Old Apr 17, 2012 | 04:13 AM
sde780's Avatar
Heh kinda looks like an LMA
Old Apr 17, 2012 | 05:34 AM
Robin6's Avatar
i agree with thos who think its the pressure relief valve. If that is in the bottom of the oil pan where is the rest of it, the spring? If that is the pressure relief valve you are running without any pressure.
New oil pump time!
Old Apr 17, 2012 | 06:21 AM
zerovandez's Avatar
Do you recall taking apart the oil pump at all? I hope you guys are planning to check the health of that head and the cam journals.
Old Apr 17, 2012 | 06:40 AM
92eghb's Avatar
I did try to open the cover on the oil pump to port it but was only able to get 2 of the Philipes screws out an the rest of them striped so I put the 2 back in and didn't mess with it after that.
philztheone
Dec 29, 2014 05:30 AM
1992TegGsr
Sep 7, 2008 07:19 PM
VSM_EJ8_408
15
Jun 20, 2008 05:05 PM
teler86
May 31, 2006 08:54 AM
eag36
Mar 30, 2005 05:40 PM
