wtt: my em1 shell for your ek hatch shell or 4dr 96-00 shell
Im looking to maybe sell my baby! she is my daily driver.
body has 192,000 miles and swap has about 50,000 miles
jdm 98 spec integra type r b18c long block
usdm 96 gsr transmission
energy suspension motor mount inserts
skunk2 pro series intake manifold
professional products 65mm throttle body
coolant throttle body bypass
ct engineering icebox intake
custom jake intake elbow made from cxracing intake
k&n coupler
ct engineering drop in filter with velocity stack
plm toda replica header w/integra type r header bracket
aem tru power steering pulley
ngk iridium plugs
walbro 255 fuel pump
stock injectors
blox fuel pressure regulator
blox fuel pressure gauge now installed
p28 phearable.net chipped ecu
obd1 to obd2b ecu jumper harness
jared street tuned chip
5400 vtec kick in
5000 rpm launch control
8250 rpm check engine shift light
act prolite flywheel
stage 2 pressure plate
act stage 2 clutch disc
stainless steel clutch line
b&m short throw shifter
energy suspension shifter bushings
civic type r shift boot
koni yellow adjustable struts
skunk2 lowering springs
blox upper control arm front camber kit
wicked tuning rear camber kit
2.5" hi flow catalytic converter
apexi exhaust piping
hks hi power ti tip axle back mandrel bent
15x8 +25 enkei 92s in black with polished lip
205/50/15 dunlop dz101
front and rear fender roll done with eastwood fender roller the right way
pioneer head unit ipod usb ready
10" sub and amp
dc sports rear strut tower bar
morimoto mini h1 retrofit projectors
ac works, powersteering works, sunroof works, cruise control works also. no cels! about 10,000 miles on motor since the swap but it had around 40k before the i installed it.
bads: driver side window is unplugged do to coming off track. normal small scratches and dings from daily driving.....rocks always get kicked up around here.
i think this is everything
$7500 obo
text only 361-288-6058
k&n coupler
ngk iridium plugs
stock injectors
5400 vtec kick in
10" sub and amp
$7500 obo
Will consider these shells for trade:
Civic hatch 92-00 manual with ac
Civic 4dr 96-00 manual with ac
If the shell comes with good suspension and wheels then I'll leave the koni yellows skunk2 springs and enkei 92s on
its now posted in this thread: http://hondamarketplace.com/showthre...1#post47301323
jakesurfin
Texas -OK -LA (Sales)
16
Jul 20, 2012 08:38 AM
jakesurfin
Jul 19, 2012 12:09 PM
Mattcheww
Dec 9, 2009 09:47 AM
bc_ef8
13
Jul 2, 2006 02:18 PM
