EGR...I can't have one 3-stage vtec
Old Apr 16, 2012 | 11:19 AM
cxtomato's Avatar
Default EGR...I can't have one 3-stage vtec
Hi folks!
I have obtained an OBD2a P2J Manual ECU. I am wanting to mate it to my 3 stage. I have an Edlebrock intake manifold...with no egr possibility.
I need help understanding how to, if any way possible, bypass the ECU throwing a code for missing it.
I understand that the HX uses a 5 wire but the JDM 3 stage uses 3. I assume power, signal, ground.
I have traced in the haynes manual (for an HX) that the power is a 5v constant supply. The problem is that the ecu would recieve different signal based on the "lift" of the EGR. It looks like at optimum conditions it would recieve a signal of 4.3v. I can use a diode to make this happen, but I do not want to short the ECU (wattage), or kick a code during warm up that may leave me in limp mode.
Anyone out there bypass their EGR sucessfully?
Old Apr 16, 2012 | 01:34 PM
zcme's Avatar
Default Re: EGR...I can't have one 3-stage vtec
Plug in a dummy egr valve. The ecu will command lift and open the egr the egr lift sensor will see the change in lift. I don't know if the jdm/edm ecus had the code for low egr flow so that may be the easy fix. You can hide the egr valve where ever you want.
Old Apr 16, 2012 | 05:32 PM
cxtomato's Avatar
I do not have even a connector for this. I have a 98EX manual harness. I am looking for a way to pin a ghost egr.
Old Apr 16, 2012 | 06:32 PM
cxtomato's Avatar
Pin out A7 to pin D9 should work, just need to know what resistance the sensor offers....can anyone meaure their resistance with the car off...please?!
Rifajnd
Jun 26, 2016 11:17 AM
ZCHondaCRX91
Jun 14, 2010 06:45 AM
2wheelhunter
Aug 15, 2006 03:12 PM
quik1
May 5, 2006 07:39 AM
whitebread_pothead
May 22, 2003 09:28 AM
