Help 98 prelude bb6 starting issue and radio code anyone??
Car seems to have issues starting, it startes and dies right away and the green key light comes on it does this twice and then the car startes and is normal. any ideas?
bit of back ground that I know car has been stored for the past 18 months was in an small accident I had to change all the direction and I have just started it back up.
I am a new owner have no other history on this.
the gas probably wasnt drained or anything for those 18 months, right? what was the accident?
if it were me, i would make sure it wasnt throwing any check engine lights and if its not, sea foam it to burn up all the crap thats probably settled in it. i bet thats your only issue.
as for the radio code, youll probably have to pull the radio out and get the numbers from the back and talk to the stealership. theyll do it for you but itll probably be more expensive than an aftermarket radio.
the guy hit a side walk only the direction was damaged both front and rear.
The only check engin is O2 sensor. I am officially puting it on the road today so will see.
as for the radio that is what I am trying to avoid steallership rates hoping someone here will be able to get it for me
went to the stealership for the radio code and stealership became freeoship loll I guess they see me often enought as for the starting issues seems after riding it a couple times all is now in place thanks
