how good are skunk2 cams stage 1
Old Oct 11, 2002 | 07:54 PM
Black DC2's Avatar
Default how good are skunk2 cams stage 1
how much HP to expect from these cams on a 98 gs-r
and any problems with these cams and would they be
good to run on nitrous a 60 shot
Thanks in advance
Old Oct 11, 2002 | 07:57 PM
MikeSarr_GSR's Avatar
Default Re: how good are skunk2 cams stage 1 (mighty goku)
what are your goals and intentions for the motor
Old Oct 11, 2002 | 08:13 PM
Black DC2's Avatar
Default Re: how good are skunk2 cams stage 1 (MikeSarr_GSR)
right now my goal is to hit low 13's with this motor right now
my head is built with ferrea valves skunk2 valve springs and retainers
so far i hit 13.8 at 102 on street tires with I/H/E skunk2 cam gears and skunk2 intake manifold also dyno at 215 to the wheels with a 60 shot trying to get 230's to the wheels hoping
Old Oct 11, 2002 | 09:45 PM
stupidfast's Avatar
cams are good for about 12whp and you might as well just bump up to a 75 shot.. your car will love it and you should run high twelves with that setup.. I ran 12.8 with the exact same setup.. good luck..
p.s. my car dynoed 237whp with that setup
[Modified by stupidfast69, 6:47 AM 10/12/2002]
Old Oct 11, 2002 | 10:05 PM
Black DC2's Avatar
Default Re: how good are skunk2 cams stage 1 (stupidfast69)
thanks for the reply stupidfast i was looking for someone to have a setup like mine
hoping to hit 12's to was that on SLICKS or DRAGS
Old Oct 12, 2002 | 05:11 AM
stupidfast's Avatar
22x8x15inch slicks at 12psi..and ive gone through alot of nitrous and never had a problem. i even went to 100shot a couple time and it did great..
2000EKCoupe
20
Feb 15, 2012 12:52 AM
EGCoupeVtec
Feb 11, 2009 06:00 AM
btk2334
May 26, 2008 08:33 AM
GSR95T
Nov 18, 2004 05:13 AM
b19coupe
Mar 23, 2002 12:29 AM
