BUDDYCLUB COILOVERS S2000 / S2K RACING SPEC W/ PILLOW BALL MOUNTS- CHEAP!
Buddy Club Coilovers for 01+ S2000 / S2K
Version: Racing Spec With Pillow Ball Mounts
Condition: Awesome
Price: $675 (Paid over $1500 new)
Factory Description:
1. Adjustment bracket
With an adoption of a "adjustable bracket" the ideal low postion can be achieved without any use of helper spring. One rotation, approximately 2mm, will enable the user to change the length of the damper. Dampers are black plated rather then painted for extra durability.
2. 15 Level Adjustment
The 15 level adjustment corresponds to variety of racing stages, from Touge 'mountain roads' to cicuits. Adjustment is easy with its click adjusting dial. The dial is located ither on the upper shaft for regular dampers or on the lower shaft for inverted dampers. This damper is also designed for town use; hence, dampening setting ranges from hard (+4kg/mm) to soft (-4kg/mm).
3. Single tube type shell case
Unlike visual based cartridge damper, adoption of the single tube shell case enables the use of wishbone type 46 and strut type 36. This leaves an extra space for larger pistons. Also this change allows for better heat dissapation, which prevents performance deterioration from hard runs. Special steel and anti-friction components are used to minimize friction.
4. Specialized Pillow-Upper Mount
Application of the upper pillow upper mount allows you to have greater handling response, by minimizing upper chasis movement. Caster adjusment allows the correction of camber for further tuning ability. Caster adjustment plates are not included on all applications.
5. Spring seat / lock seat
Each single full rotation equals 2mm drop. The adjusting locking seat allows for spring stress to adjust with out the necessity to change suspension position.
6. Original spring
Tremendous enhancement in durablity resulted from a high quality surface processing. Constant testing resulted in a perfect spring rate for each application.
HIGH GRADE QUALITY
Racing Spec Dampers inherited the same great quality of the P-1 racing damper. Each Racing Spec Damper is made with special components and are tested and produced with out compromise. Each damper are assembled by skilled engineers to provide the best quality possible.
Condition: Awesome
6. Original spring
HIGH GRADE QUALITY
xo2racing
Feb 10, 2011 11:14 AM
acuteperformance
Honda S2000
11
Aug 16, 2007 03:15 PM
jdmstylesi
11
Jan 31, 2005 04:06 PM
