H22A(USDM) head with H23A(USDM) block
Old Oct 11, 2002 | 07:00 PM
skankin's Avatar
Default H22A(USDM) head with H23A(USDM) block
If I were to put an H22A (USDM) head on my H23A (USDM) block, would I need to to have any machine work done or is it a direct replacement of the H23A head? Any suggestions for this head swap? I asked a Honda Technician that I work with and who has worked on several major engine swaps and aftermarket part installations, but he does not know. Thanks, your help is appreciated
Old Oct 11, 2002 | 07:17 PM
satan_srv's Avatar
Default Re: H22A(USDM) head with H23A(USDM) block (skankin)
https://honda-tech.com/zerothread?id=175690
Old Oct 11, 2002 | 09:42 PM
KTeller8's Avatar
Default Re: H22A(USDM) head with H23A(USDM) block (satan_srv)
when i went to a local import yard they said that the h23 and h22 blocks were showing up in the system as the same. or they just mean compatable???
i have h22 pistons, rods and other for the build i am just needing a short block. can i use a h23 and then do the sleeve and bore as normal? it would be cheaper to find a h23 block huh
Old Oct 11, 2002 | 11:14 PM
satan_srv's Avatar
Default Re: H22A(USDM) head with H23A(USDM) block (KTeller8)
They are compatible as in the use the same head gasket, if you're using the H23 block you will use H23 crank rods and pistons usually. And you have to add the VTEC oil squirters, well I would.
Old Oct 12, 2002 | 01:04 AM
KTeller8's Avatar
oh thanks
well see i have h22 in the accord and i bought pistons, rings, rods etc. for the build up. i am just looking for a faster route to gettng a short block and thought of the h23.
Old Oct 12, 2002 | 01:05 AM
KTeller8's Avatar
since i see them going cheaper. i could add the squirters in myself afterwards huh
pkolaboy
Feb 19, 2008 06:37 PM
preludefien
Sep 9, 2007 09:19 PM
Kwalsh24
Mar 20, 2006 09:22 PM
H23LUDE92
Jul 14, 2004 08:19 PM
